What is gear reduction ratio in typical outboard motors ?
Discussion in 'Outboards' started by preventec47, Aug 14, 2016.
  1. preventec47
    preventec47 Junior Member
    Maybe the ratio changes between mfgrs and among models with the
    same mfgr. I want to analyze my propeller performance and I have
    to know how fast the prop is spinning at different engine rpms.
    I am primarily focused for now in the range of 10 to 40 hp.
  2. Dieboat
    Dieboat Junior Member
    From my research and based on zero real experience, the gear sets in outboard motors range between 1.47-1.92. It appears that the higher ratios usually correspond with more horsepower; my information comes from the manufacturers sheets of higher horsepower outboards.
  3. gonzo
    Likes: 2,415, Points: 123, Legacy Rep: 2031
  4. Mr Efficiency
    I doubt you'll find 1.47:1 or close to it, back in the days before through-hub exhausts they were lower than now, but 2:1 is a pretty standard ratio today, with typically the ratio dropping as hp size increases.
  5. PAR
    Yeah, 2:1 is typical with 2:5 reserved for high thrust applications. Subtle variations do occur, probably just to be different, but 2.09:1 and 2.47:1 don't really count much in the big picture.
  6. theoldwizard1
    theoldwizard1 New Member
    Some high horsepower outboard, especially 4 stroke, have gear reduction immediatly under the power hear at the top of the leg.
    This helps keep the foot more hydrodynamic.
  7. gonzo
    Which ones?
  8. hoytedow
    My Honda 9.9 has a gear ratio of 2.33 to 1. The prop turns once for 2.33 crankshaft revs.
  9. baeckmo
    Likes: 926, Points: 113, Legacy Rep: 1165
    baeckmo Hydrodynamics
    Suzuki
  10. gonzo
    Thanks, it is an interesting solution.
  11. Steve W
    Likes: 94, Points: 48, Legacy Rep: 608
    Steve W Senior Member
    My Yamaha 9.9 high thrust has 2.92:1 reduction, about as low as I have seen, even Yamahas other high thrust offerings are not that low.
