what is a "Work PFD" vs "This is NOT a Work PFD"?
Discussion in 'Boat Design' started by Squidly-Diddly, Aug 6, 2023.
  1. Squidly-Diddly
    Likes: 187, Points: 63, Legacy Rep: 304
    Squidly-Diddly Senior Member
    IIRC I saw an inflatable vest stamped "Work" and a solid foam normal vest stamped "Not a Work PFD".
    https://www.grainger.com/category/safety/water-safety/life-jackets-and-pfds
    don't see any such definitions here. Will post pics of "Not a Work" later.
    Don't see any official info on "work" vs not work. Is "work" anything official or just more durable fabric. Hard to imagine makers stamping otherwise legal vests "not work" unless forced.
    TANSL likes this.
  2. jehardiman
    Likes: 1,452, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    It is the requirements for the buoyancy, see 46 CFR 160.001-2 and 46 CFR 160.053. Generally a "work" PFD must supply at least 17.5 lbs of buoyancy continuously while being completely submerged for 24 hours. A "standard" TYPE II or III PFD needs to only supply 15.5 lbs of buoyancy, and you really can't work in a TYPE I PFD (supplies 22 lbs). "Work" PFD's also generally are TYPE III PFD's, not TYPE I or TYPE V hybrids (i.e. a "work" PFD generally will not turn an unconscious person face up as OSHA requires personnel oversight and a rescue skiff to be present).
    Edit: Here is a typical modern TYPE V work vest we used to use for our overwater riggers.
    Stearns 3000003509 | Fisheries Supply https://www.fisheriessupply.com/stearns-inflatable-work-1471-vest-automatic/3000003509
    Edit 2: This is also a work vest we used for deck personnel.
    https://www.archwaymarinelighting.com/product/stearns-work-vests-10/
    BMcF and bajansailor like this.
