What is a Cheap alternative to Waterproof casting deck?
Discussion in 'Boat Design' started by Ryan Miller, May 16, 2019.
  1. Sean Duval
    Likes: 7, Points: 3
    Sean Duval Junior Member
    I may have done wrong with my aluminum boats....
    When changing out transom wood which I laminated with epoxy and sealed with epoxy then installed. I sealed the motor well area to the wood with sikaflex as I felt it would allow a tad bit of freedom of movement...aluminum and wood heat and cool and swell and shrink at different speeds. I then painted over it. I have been happy with the results.
    Oh...all through hull and wood holes like for the motor mounting I predrilled...used a paintbrush and epoxy sealed them too....when I installed the part or bolt I additionally used 3m 5300 marine adhesive sealant to grant me just a bit more protection as I hate leaks and positively loath soggy rotten wood. Has worked well for almost 10 yrs on my Jon boat and 7 or so on my starcraft aluminum converted to cc.
    Your mileage may vary
    Don't follow my example unless someone with more experience here says it is good .
    Ryan Miller likes this.
  2. Ryan Miller
    Ryan Miller Junior Member
    I will be using that marine sealant but it's the top I'm not sure how I will be getting the transom out yet either grind or bend the steel up it is sealed in pretty good
  3. starcmr
    Likes: 5, Points: 8
    starcmr Junior Member
    I'm always thinking about my boat and how to improve it a bit whenever I get around to doing things...my hornet has the plywood and carpeted decks which i feel is not ideal when it gets wet, cos it takes a while to dry and I think the ply may start to rot away eventually, any ideas, maybe alloy or a plastic type of product.?
  4. Andrew Kirk
    Likes: 68, Points: 18
    Andrew Kirk Pedal boater.
    A cheap way to waterproof ply is to use Titebond 3. It is a wood glue but fully waterproof even for constant exposure to water. You can also use it to laminate a layer of cloth over the ply. You can seal leaks with self adhesive flashing intended for buildings. Heat it with a heat gun in position and it's going nowhere in a hurry. You need it cheap? Ask me!
    1. Puma
    2. Squidly-Diddly
    3. lvabd
    4. Anelito
    5. boatdesingloverer
    6. Asleep Helmsman
    7. sailingrock
    8. macpatt265
    9. bjdbowman
    10. Squidly-Diddly
