what happened in a hurry for me is weight...
the way to deal with unanticipated weight is higher ppi or immersion and higher available displacement
these ought to get careful consideration
where the OPs question falls apart is 'same displacement'
they ought to vary
I realize the discussion is conceptual, but the same displacement for a 25% longer hull is impractical for the stated goals.
For a small example, this cruiser heading to Bahamas will need water, may require holding tanks, may enjoy autopilot..all add weight..
30' hulls may be habitable or just on the edge and now stairs heading into the hulls add as cushions and passengers
Anyhow, the exercise is not without its problems. The two boats really ought to vary in displacement.
Right now, I am at a point in my build where I wish I had a bit more displacement as I am nervous about weight...so offer my perspective.
A 24' cruiser will require all that a 30" requires unless you are not staying onboard at night,
