What Do We Think About Climate Change
Discussion in 'All Things Boats & Boating' started by Pericles, Feb 19, 2008.
Thread Status:
Not open for further replies.
  1. hoytedow
    I was talking about the one that elects the Democrat congresspeople(3of 4).
    They seem to be awakening now. Good for them.
  2. Guillermo
    Likes: 188, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    Diagram showing monthly variations in global cloud cover for high, middle and low clouds since July 1983. The uppermost panel shows the variation of the total amount of water vapour in the atmosphere. During the period of observations, the amount of low clouds (net cooling effect on global temperature) has been decreasing from about 29 percent in 1986 to about 25 percent in 2007. A secondary low and peak were recorded in 1990 and 1994, respectively. The amount of middle clouds (no clear net effect on global temperature) has been slowly increasing from about 20 percent in 1984 to about 22 percent in 2007. The amount of high clouds (net warming effect on global temperature) decreased slightly until around 1999, and has since then again increased somewhat. The time labels indicate day/month/year. Data source: The International Satellite Cloud Climatology Project (ISCCP). The ISCCP datasets are obtained from passive measurements of IR radiation reflected and emitted by the clouds. Please note that the step-like change in atmospheric water content 1998-1999 may be related to changes in the analysis procedure used for producing the data set, according to information from ISCCP. The cloud cover data, however, should not be affected by this. Last data: June 2008. Last figure update: 14 June 2009.
    Credit: Climate4you
  3. Guillermo
    Conclusion (for today)
    So, talking roughly and avoiding the shorter terms variations, we have seen how atmospheric water vapor and low clouds, which account for -let's say- 85% of the greenhouse effect if we accept Gavin statement, tend to decrease while temperatures increase.
    As this 85% effect is more than FIVE times the 15% one induced by CO2 alone (rough median of the 9-26 scope, following again Gavin's reasoning), it is evident something does not work at all in the AGW theory, which implies a water vapor feedback to the weak CO2 forcing to boost the increase of temperature.
    Now going to sleep. Be good all of you. :)
    P.S. I almost forgot: Any of you can check by himself my NOAA plots here: http://www.esrl.noaa.gov/psd/data/timeseries/
  4. wardd
    Likes: 37, Points: 0, Legacy Rep: 442
    wardd Senior Member
    so , dumping the co2 that nature accumulated in safe deposits over millions of years in less than 2 hundred years has no affect?
  5. hoytedow
    Nope. No effect at all.
  6. wardd
    wardd Senior Member
    really?
  7. hoytedow
    Yep. Really.
  8. wardd
    wardd Senior Member
    I don't believe you
  9. hoytedow
    Ask your duck. She knows the truth.
    Quack.
  10. wardd
    wardd Senior Member
    people of feather lie
    and she's a goose
  11. hoytedow
    Honk!
  12. Boston
    Boston Previous Member
    the complete lack of comprehension is astounding guillermo
    water vapor is a feed back not a forcing agent
    therefor CO2 being the predominant greenhouse gas is driving water vapor
    once again your complete lack of comprehension is simply laughable as is your inability to properly represent Gavins comments concerning the issue
    you might want to actually learn the basics rather than continue to humiliate yourself with these obvious errors in your postings
    the overall effect of CO2 as a greenhouse gas all things considered is aprox 10~30% of the total depending on the variations in overlaps and other reactions
    your inability to comprehend this as well as your continued posting of random data amounts to a tantrum of some kind in the face of rational debate
    do you or dont you have a comprehensive qualitative hypothesis or theory countering the present accepted theory or are you simply prevaricating with data you clearly do not understand well enough to incorporate into an actual theory of your own
    oh and I have confirmed my alumni status with one of our more level headed readers its just that I have no intention of revealing any personal information to you, our resident paid oil and gas shill. Besides its way to much fun to watch you freak out over your own errors.
    speaking of which
    maybe you missed for a third time the qualifications regarding the difficulties regarding accurate humidity readings over the larger time frame.
    from chapter 3 IPCC WG1 pg 238
    and from section 3.4.2 (p. 271, 272):
    or the simple reality of the detailed summery of several qualitative analysis of water vapor content and role in climate science
  13. Boston
    I also notice you seldom have the courage to actually post an entire article, or would that detract from your taking some few points out of context.
  14. Boston
    In a nut shell
    all the mindless blithering of the deniers camp is but a leaf in the wind compared to the tall ship called ( a working theory ) that is steering a steady course on a calm sea of science
    the random incoherent data points blindly thrown into the conversation simply dont amount to anything even remotely worthy of debate
    lacking any real hypothesis utilizing the majority of the available data and resulting in a coherent rational counter theory one can only say
    all it really is
    is another game of "find the flaw" among the misrepresented data points and misunderstood statements of another angry denier who is clearly frustrated over being found out at every turn
    simple reality is
    the truth will out Guillermo
    the truth will out
    entertaining to some degree but all in all
    boring what with so often the same flaws being so obvious and easily outed
    which in this case was already established a few pages ago and our local denier simply chose to repeat his earlier misrepresentations
    atmospheric water vapor has long ago been shown to be on the increase and some few cherry picked bits of data simply are not adequate to fool the readers
    nice try though
    lots of superfluous data repeated numerous times in an effort to flood the readers with improperly presented half truths and thinly veal'd attempts to challenge a well established working theory
    typical tactics
    typical vitriol
    typically exposed
    once again for all to see
    thanks for playing "find the flaw" Guillermo
    can we at least try and make this next round a bit more challenging
    tell you what
    why dont you take your time and really think this next one through
    my bet is I can "Find the Flaw" in less than an hour from the time of my reading your next
    what do you say
    care to try again
    love
    B
    PS
    I notice you were unable to define the difference between relative humidity and specific humidity
    nor were you able to describe why one might remain stable while the other might rise with a change in temp
    or a change in pressure for that mater
    you might stick to things you actually know about ( beer, bars, dancing girls, cross dressing ) rather than go on about things which you clearly know nothing about
    like climate science
    just sayin
    cheers
  15. hoytedow
    Have a nice day.
  1. rasorinc
  2. El_Guero
  3. troy2000
  4. gonzo
  5. gonzo
  6. Grant Nelson
  7. Boston
  8. Boston
  9. hmattos
  10. brian eiland
Thread Status:
