What Do We Think About Climate Change
Discussion in 'All Things Boats & Boating' started by Pericles, Feb 19, 2008.
Thread Status:
Not open for further replies.
  1. gonzo
    Some answers are so long and rambling that it would take several pages to discuss. It is very wrong the statement the science is by consensus. One solitary proof is all that is needed to bring a theory down. Consensus works in politics and social issues. When we talk about global warming from those point of view then science is not a consideration,
  2. Boston
    Boston Previous Member
    going to do a little cut and pasting to try and get through these next few elements of basic physics so we can move forward and have a productive conversation
    basically radiation exists in the form of electromagnetic waves
    the shape of the wave is can be thought of as a sign pattern
    a snake like line
    if this pattern is more than double the size of the object in its path
    it can go around it
    the larger the sign wave is from the object in its path
    the more waves will pass freely past that object
    the dynamics of the water vapor vs water droplets in reflecting certain types of radiation and not others is based on the amplitude and the frequency of the energy coming both from the sun and being reflected off the surface of the earth
    basically amplitude is the height of the sign wave
    with frequency being the number of wave peaks passing a given location in a specified amount of time
    and wave length is the distance between peaks
    what this is leading to is that certain wave forms pas through certain gasses more easily than others depending on the size of the wave form and the size of the gas
    another thing to remember is that the gas is evenly distributed in available volume so its effect equals 100% its ability to reflect a given type of radiation over the entire volume
    obviously the earth is not covered entirely by clouds at any given time and the pat answer for how much area is covered depends on who you ask
    ild like to agree on 50% since its about the most common answer I found although for the sake of piece Im willing to consider other numbers
    a definition of albedo might come in handy right about now
    now the properties of solar radiation should be easily agreed on
    and the physics of how that solar radiation might pas through some gas or water droplets is what we need to work on
    a gas is an atomic or molecular substance obeying the ideal gas laws
    and not all gasses are created equal
    take water vapor and say co2
    one may allow solar radiation to pas more easily than another
    so the question is
    does the size of the atom or molecule of a gas alter the way a wave form will pass through that gas
    any thoughts on that or do you folks think that varying atoms and molecules should reflect varying wave forms in the exact same manor and to the exact same degree
    once we can establish an answer to that question we can move on
    I refuse to just talk to myself over hear so if you guys want to engage in a peaceful and productive conversation agreeing on a few things is whats going to facilitate that best
    this one simple questions seems like the perfect place to start cause a correct answer establishes a few basics
    and is completely obvious
    Ill repost this as I need to but agreeing on a few of these fundamentals is crucial to understanding the more intricate interactions
    gonzo we will get to our discussion as to the ethics of science and how it is conducted once we can establish a few basics
    if we try and take everything at once as we have been then we're going to be getting nowhere fast
    Ill try and keep things as succinct as possible
    B
  3. Jimbo1490
    Likes: 41, Points: 28, Legacy Rep: 527
    Jimbo1490 Senior Member
    Boston,
    There's really no need to get this basic. Everyone following this subject into this kind of detail has already studied the differing absorptive spectral bands of the various gases involved. This is purely academic at this point and a complete understanding of this will not answer all of the climate realist's objections.
    This is essentially just more condescension on your part wherein you assume that the reason we disagree with the 'AGW via CO2' hypothesis is that we just don't sufficiently understand all of this 'well treaded' pedestrian science that you believe underpins it all. Gosh, if we could just get it through our thick heads:rolleyes:
    Nothing could be further from the truth both with respect to your assessment of both our level of understanding and objections and to the notion that all the technical points of the AGW alarm hypothesis are well supported in the basic sciences!
    What makes your attitude more ironic is the fact that you previously (before participating in this thread) held several viewpoints or understanding of the mechanisms of AGW that the AGW alarm camp does not in fact share; viewpoints that have NO basis in the basic sciences, such as that CO2 is an important greenhouse gas by itself.
    On the point you are trying to make now WRT radiative absorption, we just get back to Beer-Lambert versus 'Mikey Mann's Virgin Stratosphere'. In this case, Beer-Lambert is the 'well treaded' science while the MMVS is not only unproven, but in any event not happening since the stratosphere has exhibited a substantial cooling trend. Particulates don't make it up there in any sufficient quantity to allow you to throw up that particular red herring to save the MMVS red herring; you'll just have to accept the fact that the earth is not impressed with the MMVS theory.
    So skip to the end and do tell us, how and why additional CO2 matters when we are basically saturated at anything over 250ppm, according to Beer-Lambert?
    Jimbo
  4. Boston
    there is an obvious need to get this basic when every single detail of the obvious is argued by deniers
    only thing to do is take it back to the ultimate basics and follow it logically to its conclusion
    by understanding why certain molecules reflect various wave lengths better than others it will be possible to establish why co2 is considered a strong green house gas
    why and how clouds are considered in the mix and why co2 drives vapor content in a forcing that can only result in greater warming
    assuming the basics are understood the conclusion is inescapable
    so the question remains based on the basics that no one seems to be disagreeing on
    the question is
    essentially if this thread is designed to resolve the issue and determin if there is validity in the claim that the earth is warming and that warming is caused but humans then no one on either side should have any trouble agreeing on the basics and seeing were it leads
    or are you now going to argue these most basic of tenants
    if you admit them
    your dogmatic grip on denial is in deep trouble
    if you deny them
    everyone can see it for what it is
    an obvious break from reality
    Im just trying to as peacefully as possible get to the bottom of the denial and find out were it really starts
    if there is no actual denial then you should have no trouble answering the questions Ive presented
    if there is denial
    then you will
    as you have so far
    continue ignoring the posts and insist on jumping past the basics
    so as to hide the exact location of the denial
    my position is that in order for deniers to hold he position they do they must deny basic physics at some point
    If Im wrong you should have no worries following the basics up to there use in rapid climate change theory
    if Im write you will do as you are doing and attempt to distract the logic path
  5. fasteddy106
    Likes: 17, Points: 0, Legacy Rep: 171
    fasteddy106 Junior Member
    Looks like someone sobered up, goody. The above is facinating but hardly a revelation. The one area that Boston doesn't address is evidence. With the exception of a single paper by James Hansen, the entire scientific community now accepts that CO2 follows warming and that CO2 feedback play an insignificant part in temperature increase. Without a smoking gun exhibit of anthropogenic CO2 increases causing warming, all of this is just an exercise in mental ************. The evidence of CO2 driven heat is not there. Earlier Boston mentioned melting, ice may or may not be melting, but that is not evidence of AGW. The oceans may rise, but not because of human activity. Mumbai may flood, but CO2 won't be the villian. None of the facinating posts of scientific data are meaningful unless they show conclusive proof that increases in CO2 caused by the human race will tip the atmosphere into a non-stop warming cycle. They don't and they can't. In fact, the earth slipped into a glacial period during one of the highest ever concentrations of CO2.
    As far as the civil tone???? Perhaps if Boston refrained from calling folks stupid simply because they question his dogma on Climate Change. Perhaps thats the problem, dogma belongs in Church, science relies on evidence. I remember Dr. Burner, Lyman Hall High Schools Science Dept. Chairman. He started every year by reminding us that Science is based on evidence, and that evidence should always be questioned, for in questions lie the possibility of learning and knowledge.
  6. Jimbo1490
    And this is where you are DEAD wrong!
    Basic physics of absorption says we are saturated with CO2 right now and so additional CO2 won't matter. Basic physics tells us that the greenhouse effect can never raise the earth's temperature above its black body temperature. This temperature establishes the maximum that the earth could ever reach under any circumstance as a result of radiative absorption, so there's absolutely no need to ever worry about the hobgoblin of a runaway greenhouse effect from such trivialities as a small rise in the trace gases like CO2.
    Another way of looking at is is that the Earth has already experienced a 'runaway' greenhouse effect thousands of times during its lifetime. Each time the global temperature rose to the maximum possible level that it could (somewhere near the 'black body' temperature), bringing us the much more habitable climate that we have today, which is a decidedly pleasant break from the ice ages. It is not possible for there to be a tipping point that spirals us into a third metastable climate state that has not been shown to have ever existed during the entire history of Earth. It this were possible, certainly it would have happened when the atmospheric CO2 levels were 10X or 20X what they are today. So barring a sudden change in input from the sun, changes in climate upwards can only occur smoothly, in a slow and limited fashion. A tipping point towards another ice age is a different argument; that has happened before.
    Jimbo
  7. Boston
    hey hey the village idiot is back
    no Id call you stupid any day since the rational behind my plea for civility obviously fell on deaf ears
    there was obviously no civil intent from the moment you first embarrassed yourself
    and your still struggling to try and make even more of an *** of yourself than you already have
    why
    because your pathetic assertions are blatantly falsified in order to support the industry view
    at least Jim is able to recognize the benefit of a more adult conversation
    you on the other hand are obviously incapable of acting in an adult fashion
    my bet is you were an only child and threw a lot of tantrums
    I notice your all over the classic industry tactic of claiming there is no proof when we all know that the huge majority of evidence clearly supports the theory
    once again
    there is no coherent competing theory
    there is no debate to be had as the evidence is overwhelming
    the only effort to continue the debate is brought on by industry and its pundits in an effort to prolong there profits at the expense of the rest of us
    industry cannot force the scientific community to consider its agnotism so they spread there spin in other ways
    like on this thread for instance were the tactics of denial are so self evident
    Jim
    if you are right then why are you so resistive to answering the questions proposed
    I notice you have still not made clear your position on how a wave of a given size behaves in conjunction with particles of varied size
    its pretty obvious that if a wave form of a given type encounters an atom or molecule of varied size its going to react accordingly rather than in exactly the same way no mater what size the gas particles are
    its getting obvious your avoiding admitting something
  8. Boston
    a momentary deviation from attempting to get some agreement concerning the basics
    was having coffee with a buddy of mine from NOAA which is right up the road from me and he pointed out that we have likely reached a tipping point regarding co2 in the atmosphere
    with the following being the % of increase over the last few years
    1959 0.95
    1960 0.51
    1961 0.95
    1962 0.69
    1963 0.73
    1964 0.29
    1965 0.98
    1966 1.23
    1967 0.75
    1968 1.02
    1969 1.34
    1970 1.02
    1971 0.82
    1972 1.76
    1973 1.18
    1974 0.78
    1975 1.10
    1976 0.91
    1977 2.09
    1978 1.31
    1979 1.68
    1980 1.80
    1981 1.43
    1982 0.72
    1983 2.16
    1984 1.37
    1985 1.24
    1986 1.51
    1987 2.33
    1988 2.09
    1989 1.27
    1990 1.31
    1991 1.02
    1992 0.43
    1993 1.35
    1994 1.90
    1995 1.98
    1996 1.19
    1997 1.96
    1998 2.93
    1999 0.94
    2000 1.74
    2001 1.59
    2002 2.56
    2003 2.29
    2004 1.56
    2005 2.55
    2006 1.69
    2007 2.17
    2008 1.66
    so not only is co2 increasing
    but its increasing faster and faster all the time
    the snow ball is rolling and going faster all the time
  9. Jimbo1490
    But you can't even show that this CO2 increase is due to anthropogenic sources so WHO CARES!!!!
    The fact that you just feel it's the result of fossil fuel burning isn't enough; since the isotopic 'fingerprint' of ancient carbon is way different from recent, this is an easy question to settle.
    All the mass-balance studies show that the CO2 in the present atmosphere is not in any significant way,sourced from ancient (fossil) sources but is the result of recent terrestrial and pelagic biotic sources. The cumulative average result is 97% natural, 3% fossil.
    Jimbo
  10. Jimbo1490
    Look dude,
    Nobody following this thread is even the least bit interested in your transparently condescending little 'physics lessons' made all the more ironic by your past misconceptions about your own camp's positions.
    If you have a point to make, then just make it!
    Jimbo
  11. Boston
    do you really not recall the two or three page conversation regarding the isotopic evidence that clearly showed a significant portion of atmospheric co2 to be caused by fossil fuels
    or the graph that you posted in defense of your position that you misread and instead of it showing what you had hoped it would, proved the point exactly at what
    27% of atmospheric co2 as being directly attributable to fossil fuels
    I could go back and quote the fifty or so posts regarding this issue but there would be no point if the basics are not understood
    which is the point of my latest attempts to get to the bottom of the deniers cult
    at what point is it necessary to break from established science in order to support the industry and deniers view
    seems like if Im wrong about this that some folks would not have a problem following along
    so again
    what is your position on the characteristics of a given wave form to move through various gasses of various size molecules
    would there be a higher reflectivity in some kinds of gasses over others
  12. Boston
    is anyone else noticing that the deniers are extremely hesitant to discuss the basics
    with only Jim having the courage to even remotely dance around the edges
    could it be that in order to deny the science of rapid climate change it is necessary to deny not only how science works but the very tenants science is based upon
    its getting really obvious the deniers are avoiding something
  13. fasteddy106
  14. fasteddy106
    Yup, now that's what I call conclusive evidence! The oil industry is just sitting back and thanking guys like you Boston, their profits have never been higher since new drilling has come to a near halt. Seeing as how the nuclear option is shut down and wind and solar will never produce enough for the U.S. economy, our only options are economic contraction with draconian regulations over every aspect of human existence, or just keep going the way we are keeping research strangled by the AGW bogeyman, and wasting fossil fuels to produce electricity. Great plan ya got there Boston, not sure what the goal of your plan is though, you don't seem to mention that. Gee, got a bit shrill again at the mention of sobriety and civility in the same sentence, got a problem you want to share with us?
  15. Boston
    once again fails completely to comprehend the simplest of points regarding the climate change issue
    or maybe is just in denial of how science works
    in math there are proofs
    in science there is preponderance of evidence
    in the field of climate change there is so much evidence that a panel was created to collate and provide a determination
    science working on what the majority of best evidence was, formed a consensus, and determined that there is significantly greater evidence that global warming is caused by human interaction with the climate system than there was evidence suggesting global warming was not caused by the interaction of man
    seems pretty simple and 97% of scientist agreed
    industry, however, is still crying foul and doing all it can to spread doubt in the face of what amounts to one of the largest consensus ever in he history of science
    Thread Status:
