What are the pro's and con's of building in...
Discussion in 'Boatbuilding' started by BillAU, Feb 22, 2013.
  1. BillAU
    BillAU Junior Member
    Not being an expert in boat building I was wondering, what are the pro's and con's of building, owning and maintaining a boat built in Foam sandwich, Epoxy on Ply, Straight Fibreglass, Steel, Aluminium, Timber or Ferro Cement.
    Bill
    Australia
  2. FMS
    FMS Senior Member
    Solid fiberglass -
    pro: ease of repair
    con: working with resin isn't everyone's pleasure
    Cored FRP -
    pro: lighter weight
    con: can deteriorate if not sealed well or damaged
    Ferro -
    pro: cost
    con: no resale value because buyers can't easily determine condition of steel within
    Steel -
    pro: dents before breaking ;) durability
    con: not appropriate for every boat
    Plywood -
    pro: strength/weight+cost
    con: maintenance and degradation when poorly sealed
  3. Submarine Tom
    Submarine Tom Previous Member
    Personally, I'm fond of glass on ply but if I were to do it over again, I'd go for steel.
  4. pdwiley
    Likes: 89, Points: 48, Legacy Rep: 933
    pdwiley Senior Member
    Completely meaningless question without stating what your requirements for the boat are.
    PDW
  5. Landlubber
    Landlubber Senior Member
    You really MUST tell us the design and use of the boat, there are all these materials of choice, cos choice is what makes every boat individual....you can use canvas and wood to make a very good boat (if it was for a lightweight kayak), but ferro is not so good for a light weight kayak is it?
  6. FMS
    FMS Senior Member
    This is true.
    Describe the parameters of the boat you are considering Bill.
    Then a list of material pros and cons can have meaning. Don't underestimate your own capabilities, facilities, and preferences should this be a boat you are planning to build yourself. Preferences include what type of maintenance you enjoy doing and on what cycle and how long you want the boat to last and in what aesthetic condition.
