Hey guys, first post. My boat is only a year old but the trim tabs were rusting bad, and I thought I noticed some water leaking from the area. I decided to pull the tabs and found there was hardly any sealant used on the install of the tabs, and the holes were not countersunk before the screws were driven in (So lot's of chipping and cracking of the gel).
I drilled out the existing holes to 3/8", and ground out any remaining cracks and chips in the gel that still remained.
My plan now is to:
1) Fill in any remaining cracks/chips around the new 3/8" holes with new gelcoat. And then sand back flush.
2) Add a small chamfer to these new 3/8" holes that I drilled, using a countersink flute bit.
3) Fill the holes with Six10 and tape over.
4) Once cured, sand back flush and Drill a new pilot hole.
5) Use number 10 or 14 screws to attach the tabs while bedding the tabs in either 4000 or 5200.
Are 3/8" holes with Six10 appropriate? The transom is about 1" thick, and the holes go straight through the core of the transom, so I want to make sure it seals it up really well. The transom is no wood construction, and inside the boat is filled with closed cell foam. But a decent amount of water poured out when removing the old screws, so I know water was getting in there. I currently have the boat tipped to the stern in the driveway with heat lamps and fans on it to dry out any remaining moisture that I can.
I attached some photos showing the holes after I pulled the tab with the rust still on there, and then some photos of the holes after I cleaned up the rust so you can see what I was originally working with.
My plan now is to:
