Welding a file to mild steel
Discussion in 'Materials' started by valvebounce, May 13, 2015.
  1. valvebounce
    Likes: 15, Points: 18, Legacy Rep: 124
    valvebounce Senior Member
    I have mislaid the winch winding handle for my boat trailer.
    After searching,it seems unlikely that I can purchase a new one because they are not available.
    The winch is perfectly serviceable.
    I have made one from mild steel with the required offset and handle,unfortunately it has rounded off across the flats where it fits on the winch drive.
    My idea is to cut a slot in a metal hand file,and weld it to the new handle.
    The drive shaft on the winch is a threaded shaft with 8mm flats on it.
    Is it possible to weld file steel to mild steel?
    I would of course cut the file to size before welding.
    My only other option is to have one fabricated,which would probably cost as much as buying a new winch.
    Kind regards
    V
    A photo would help. Files are usually made of a soft inside metal and a hardened outside. It is not impossible to weld, but extremely difficult. The hardened surface is likely to crack with the stress when cooling. The file will wear out the winch, which is more expensive than an aluminum flat bar.
  3. Canracer
    Canracer Senior Member
    gonzo is right, it would be best to post a picture. My first thought is that hardening another mild steel handle would be easier.
  4. waikikin
    waikikin Senior Member
    As above the file is a poor choice of material for the purpose. However fairly straightforward to weld a file or piece thereof to other steel, I've done successfully in past just using some 316L electrodes in the application of creating pneumatic "jerry" irons for removal of caulking materials- used in air hammer, most important is a smooth transition of thickness of the parts & some detail in backgrinding- stringer beads & tapering of transition. So far as I'm aware only the tang of the file is soft.
    Jeff.
  5. rwatson
    rwatson Senior Member
  6. Jammer Six
    Jammer Six Previous Member
    Or you could look for the handle with the same level of effort and amount of time research, development, design, welding, fitting and finishing a new handle would require.
    That wouldn't even need a picture.
  7. Barry
    Likes: 583, Points: 113, Legacy Rep: 158
    Barry Senior Member
    It would be almost impossible to case harden mild steel as mild steel does not have a high enough carbon content to increase the hardness by quenching. The normal hardening process. Water, oil, salt, baths
    As millions of winch handles are made from mild steel, it would be much cheaper and easier to just get a heavier thickness of handle material, so the slot will not wear out, and just ensure that the slot fits tight over the winch input shaft.
    If you are starting from mild steel and trying to harden the surface you could carburize the mild steel, then quench, but this is quite a technical process to be done correctly
    I would suspect that a winch handle made from say flat bar 1 1/4 by 3/8 thick, would outlive the life of the winch
  8. valvebounce
    Many thanks for your replies guys,
    Sorting through the answers,I think I will go for the 3/8" flat bar idea.
    Probably take it to cherry red and quench it,and not bother tempering it.
    When I was in engineering many years ago,they used cyanide to case harden with,and could vary the depths upto 25-30 thou.
    I should imagine obtaining cyanide in this country these days would be nigh on impossible,you need a certificate to open your front door these days.HaHa.
    Once again,many thanks
    V
  9. Mr Efficiency
    Hey V, you need a thick slot washer, weld to your handle.
  10. pdwiley
    Likes: 89, Points: 48, Legacy Rep: 933
    pdwiley Senior Member
    Not the case (ha ha). There are a number of compounds like Kasenite that can put a hard case on mild steel.
    Mild steel doesn't have enough carbon to be hardened by heating & quenching. That's not the same thing as case hardening.
    That said the idea of welding a file onto something is poorly thought through. I wouldn't contemplate that. Use normal flat bar.
    PDW
  11. gonzo
    Heating in an oxygen rich atmosphere will rob mild steel of carbon and it will be softer after quenching. Hardening has to be done properly to get the expected results.
  12. valvebounce
    Nice one Mr E,now why didn't I think of that.
    I once made a gearlever for a 500cc bsa shooting star from round bar and flat bar.I blew the splined hole through with a propane torch,and tapped it onto the splined shaft.
    I had jumped a humped up railway line on a bush track in Whyalla,when I went to go up the box,oops no gearlever.I was in third gear,and did a lot of clutch slipping to get home.
    There was a two month wait for parts from Birmingham in the UK,so I made one.
    I worked in a shipyard for BHP,and all that was available toolwise were boilermakers tools.
    (Bush mechanic) HaHa.
  13. valvebounce
    I should have known that from my metalurgy days Gonzo,
    age fuzzes the memory,although I can still remember my first lady,funny innit.HaHa
  14. Canracer
    I did some internet searching ("can mild steel be hardened") and it seems that, no it can't. I guess a small amount of hardness can be had but only with complicated and sometimes toxic quenching techniques. Careful you don't tear apart the winch shaft with that harder handle.
  15. valvebounce
    Hi Cr,thanks for searching,
    the hardening process would work,but to tell you the truth,it wouldn't be viable financially.
    I think the thicker flat bar idea would solve the problem (Maybe 3/8")
    I can cut the slot out by drilling either end of the slot with an 8mm drill,and cut out the middle bit and file it.(The slot is 8mm)
    Providing the slot is a tight fit,I think it will work without hardening it.
    I have another boat trailer with a winch on it,which is similar and it is just mild steel.
    Thanks for your interest
    V
