Weirdest propulsion system
Discussion in 'Propulsion' started by gonzo, Jan 12, 2010.
  1. SamSam
    SamSam Senior Member
    This is weird...
    http://images.google.com/imgres?img...el=s&rls=org.mozilla:en-US:official&sa=G&um=1
  2. kistinie
    Likes: 8, Points: 0, Legacy Rep: -74
    kistinie Hybrid corsair
    No, Nothing ;-)
    Rotor boats are not as crazy as it may sound.
    The first boat equipped like this in 1926 crossed Atlantic via south America.
    Reported speed was 4 to 9 Knts
    One of the last try was in 2008 on a 130 meters cargo built by Lindenau-Werft shipyard in Kiel.
    Any news of this boat?
    In 2009 the Finland-based maritime engineering company Wärtsilä unveiled a concept for a cruiseferry that would utilise flettner rotors as means of reducing fuel consumption.
    http://en.wikipedia.org/wiki/Rotor_Ship
    More on Magnus effect (also used in Boomerangs and golf balls)
    http://en.wikipedia.org/wiki/Magnus_effect
  3. powerabout
    powerabout Senior Member
    also used on stabilisers on high speed craft ( like 20+knots) but in the water
    Just for interst sake,,how about a 80m vessel that uses Voith Schnider thrusters as main propulsion????
    ALL electric too....
    I hope to have a job on that soon
  4. jehardiman
    Likes: 1,515, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    You know, depending on how it was set up, it may work....not very efficient, but you can make inertial proplusion systems.
    http://books.google.com/books?id=B-MDAAAAMBAJ&pg=PA167&lpg=PA167&dq=popular+mechanics+black+box+moves&source=bl&ots=Zu571M81Vp&sig=jQ6JHusxPhDxC9onEH9kwaEJ6Gs&hl=en&ei=o2RsS6LBDJOmsgObmd2yDQ&sa=X&oi=book_result&ct=result&resnum=6&ved=0CBwQ6AEwBQ#
  5. CDK
    Likes: 149, Points: 63, Legacy Rep: 1819
    CDK retired engineer
    Yes, you can move a small boat by shifting your body weight or running back and forth, fast in one direction, slow in the other. The math is complicated, keywords are mass, delta V and friction.
    There are machines to compress and polish a fresh concrete floor in factory buildings so it needs not be painted, yet absorbs no oil or water. Some sort of wide cast iron sledge with a counterweight, engine and cabin spring mounted on top of it. No drive train, no wheels, just a hydraulic system to change the angle between sledge and counterweight. The driver has a control stick and a throttle pedal and can move the vibrating heavy machine in any direction.
    By converting part of the energy in one direction only from kinetic to thermal by applying local friction, the resultant vector in the other direction is larger and can propel a vehicle.
  6. Boston
    Boston Previous Member
    obviously you guys have not had the always exhilarating experience of operating a large rotary floor sander with say a 40 grit paper on it
    you control the direction by adjusting the angle of attack
    assuming you dont dig a hole in the floor first that is
    sane basic idea as above I just never knew what it was called
  7. CDK
    Yes Boston, the same principle.
    You could even move your boat with it as long as there is any floor left.
  8. peter radclyffe
    Likes: 111, Points: 73, Legacy Rep: 680
    peter radclyffe Senior Member
    Master Whisk, Variable Speed, Whisks Up To 5 Gallon, Beats Up To 50 Eggs
    Dynamic International - Model 048-FT97
    SKU: FT97
    Shipping Weight: 10.00lbs.
  9. SamSam
    How about a lifesize putt putt boat? Maybe a full size one powered by baking soda?
  10. baboonslayer
    Likes: 2, Points: 0, Legacy Rep: 32
    baboonslayer Junior Member
    I have a weird one that I just thought of. Might not work, don't really care anyway. This idea for an almost perpetual motion motor popped into my head...
    it is pretty simple. The same pole magnets repel, creating a force offset of the crankshaft, creating rotational energy.
    another weird one to try is to put a rudder on a small boat, preferably a wide bladed one, and attach to the stern etc., then try moving the tiller handle back and forth so the rudder flaps like a fish's tail. The boat should move forward. (this might actually work :D).
  11. hoytedow
  12. troy2000
    troy2000 Senior Member
    Ever heard of sculling?:p
    I've moved small boats short distances by working the rudder the way you describe. But it won't get you very far very fast, for the amount of work put into it.
  13. SamSam
    I believe you've just invented sculling and the electric motor. I too believe they might work. ;)
  14. dieseldude
    dieseldude Junior Member
    weird engine
    Weirdest engine I ever worked on was a Deltic in the old "Nasty" type patrol boats.:rolleyes:
