Weight of Plywood
Discussion in 'Wooden Boat Building and Restoration' started by Trevlyns, Jul 2, 2007.
  1. Trevlyns
    Likes: 34, Points: 0, Legacy Rep: 461
    Trevlyns Senior Citizen/Member
    Hi guys
    Does anybody have to hand the approximate weight of plywood? I’m looking for 6 and 9 mil either per square meter/foot or standard 8 X 4 sheet.
    Thanks in anticipation
    Take care!
  2. Steve B
    Steve B Junior Member
    Trev,
    6mm usually 2 - 2.4 kg/sq mtr depending on type. 9mm half as much again. www.marineply.com has lots of info.
    Cheers
    Steve
  3. Trevlyns
    Much obliged Steve. Thanks for a quick reply ;)
  4. PAR
    Species is quite important, which did you have a question for? An example would be two BS 1088 sheets, one of Okoume, the other of Mercanti which will be 20% heavier. It may not seem like much, but could be substantial for calculations in small craft design or the hull shell weight. In other words, a stitch and glue design displacing 2,000 pounds could be 2,400 pounds if you're not careful. In small craft, excess weight is a performance killer.
  5. Raggi_Thor
    One 6mm Okume I had was 2.8kg/m2, another 9mm spruce core with oukume outside was 4.7kg/m2.
  1. ned L
  2. OrcaSea
  3. shadroequiche
  4. Sunburned One
  5. sdowney717
  6. Travis Grauel
  7. Paul D
  8. Floatything
  9. juan manuel luna
  10. Old salty
