Weight Estimate
Discussion in 'Boat Design' started by Farley, Apr 15, 2011.
  1. Farley
    Farley Junior Member
    Does anyone have any data on the weight components of a 30m monohull?
    the weight estime is a relatively important factor to a good design and the one i have done is down 18 tonnes!
    the vessel is going to be a research vessel, monohull, 10 persons on board. aluminium construction.
    the structure i have calculated but i know little about more random facets that make up a boat such as the electrics. all i could find was this
    Thanks for any help offered
  2. daiquiri
  3. Ad Hoc
    Likes: 855, Points: 113, Legacy Rep: 2488
    Indeed it is. It forms the whole design whether it shall succeed or fail.
    However, you need to be a bit more specific....what type of 30m monohull...L/B ratio plays a part...as does speed...so does which rules and regulations....payload....what is the SOR etc etc. Otherwise it is like comparing a mini with a ferrari..they both have 4 wheels, both are cars both carry passengers etc....
    This "simple" mono hull, of 30m LOA has the following:
    Group 1 Hull = 24 tonne
    Group 2 Propulsion = 10 tonne
    Group 3 Electrics = 4 tonne
    Group 4 Comm. & Control = 1 tonne
    Group 5 Aux. Systems = 6 tonne
    Group 6 Outfit = 8 tonne
    Group 8 Fluids = 0.5 tonne
    Margin 5% = 2.5 tonne
    So the total lightship is around 55 tonne.
    This is for a mono of L/B =5
    Top speed 25 knots
    Carrying 35 tonne cargo.
    This might help..
    But you wont get too many weight sheets available publically.
  4. Farley
    research monohull, specs are
    LOA = 30
    BOA = 6.7
    Tc = 1.8
    top speed = 20 knots
    displacement = 123 tonnes.
    Aluminum hull and superstructure
    IMO and SSC
  5. Ad Hoc
    The figures i quoted above the full load is 120tonne, so similar to your 123 tonne.
    Big differnece is the machinary...more than double...so that can't be correct!...and a crazy amount of fuel too.
    Otherwise rest is not far off.
  6. daiquiri
    I'm sorry, didn't read your post correctly. You were actually asking for a weight breakdown, while the links above give only total operative weight of different ships. My fault :eek:
  7. Kobus Potgieter
    Likes: 1, Points: 0, Legacy Rep: 10
    Kobus Potgieter Naval Architect
    Just done a design now and completed the construction of a 30m Patrol ALU boat.
    view www.navaldesign.co.za
    They weight (Full displacement) came in at 110 T.
  8. DCockey
    DCockey Senior Member
    Are you a student?
  9. Doug Lord
    Doug Lord Flight Ready
    Yes, he is:
    22-2011, 07:41 AM
    Farley
    Junior Member Join Date: Jan 2011
    Rep: 10 Posts: 15
    I have been set the task of analysing a sailing yacht's keel using a program my lecturer has made ( it uses ISO 12215)
    For this I need information about a specfice model/yacht's keel configuration.
  10. gonzo
    It can be anything. What you have to do, is list every component, including accessories, water, fuel, etc. and add it all up.
  11. starich
    starich Junior Member
