Weed eater engine conversion
Discussion in 'DIY Marinizing' started by Ward, Jun 2, 2003.
  1. beekbuster
    Likes: 2, Points: 0, Legacy Rep: 28
    beekbuster Junior Member
    in ca there is no registration required under 4 hp. i used a youngs t 10 because it turns in the direction of the motor. if you use the gear head of the whacker you need a t 8. i built the shaft with a 1 in od 3/4 id alum. with oil impregnated bronze bushings. 3/8 stainless shaft filed down to fit the female end of the clutch drum. i then cheaped out on the lockout plate by punching a couple posts through the drum towards the engine making sure they both contacted the hardend steel t shaped deal of the clutch (i took off the clutch boots leaving the portion threaded to the shaft). then i welded the drum to the t shaped deal. had some clearance issues with the bearing keepers, but theyre not needed with the drum fastened to the motor
  2. Yobarnacle
    Likes: 130, Points: 63, Legacy Rep: 851
    Maybe a Bangkok style "long tail" boat motor from the weed eater engine. :)
  3. hoytedow
    I like this thread. It introduced me to the forum beginning with post #602. :)
  4. wildwatson
    wildwatson Junior Member
  5. wildwatson
  6. wildwatson
  7. beekbuster
    its worth a try, but i think 28cc would be too much gun for those little things,you dont know til you try. i just went with what many other people have been successful with.
  8. parkland
    parkland Senior Member
    What about a leaf blower, with a snorkel on the engine air intake?
    Just shave down the fan a bit so it doesn't grab enough water to stall it.
    70$ water jet power lol
  9. beekbuster
    that is hilarious.
  10. Hughes36
    Hughes36 New Member
    I also looked around for a weed eater outboard, but did not find anything I liked. So about 5 months ago (April, 2013), I decided to build my own. After I mounted it on my dingy, I got a lot of "thats great" from the local group, so after testing it for a few months I built some more. I call it a "WaterWacker". I made 10 of them, put some on eBay and this weekend I'm planning on going to a Marine Flea Market in West Palm.
    It works pretty well, I get about 6 knots in a two seat Kayak, a canoe should be about the same. If you are going to build one, I could give you a few pointers. There is a picture of it on eBay, search "waterwacker outboard motor". Wish you luck, its a fun project.
  11. Erich_870
    Likes: 2, Points: 8, Legacy Rep: 29
    Erich_870 Junior Member
    Wow! You must have great supplier for motors if you can sell the whole thing built for $100!
    Erich
  12. Hughes36
    Hughes36 New Member
    Well, I sell a Kit for $100, the kit has the motor mount, propeller, and various other parts required for the conversion, the completed unit is $300. Since I just started, I really don't know my cost yet. When I started my goal is $200 for the completed unit and $50 for the Kit, but I have a ways to go.
    But that is not what this form is about; the thing is, weed eaters make a great small outboard. The completed unit weights only 13 lbs, so you can easily hold it in one hand; and it hardly uses any gas. You also have to pull it several times to start it, but it is easy to pull so its not so bad. I've looked at both expensive 4 cycle weed eaters and really cheap ones. The way I see it, Once you have a kit of parts... if the weed eater craps out, just move the parts to a new one, and you are back in business.
    One thing to note is that propeller size is important; since a weed eater has a centrifugal clutch, if the prop is too big you will burn up the clutch.
  13. wildwatson
    both tanaka and shindawa (cruz-n-carry)made tiny outboard motors.from what i understand the epa put a stop to it.if the lower unit and props were still avaliable they would be awsome for a kit.the shindawa were 1.5/1.7/3 and 6 hp. i have a 1.5 . we tied 7 canoe's togather to get down the river towed by my little outboard.
  14. wildwatson
  15. wildwatson
