Weed eater engine conversion
Discussion in 'DIY Marinizing' started by Ward, Jun 2, 2003.
  1. *Ender*
    *Ender* Junior Member
    See post #282
  2. hoytedow
    Likes: 257, Points: 93, Legacy Rep: 2489
    hoytedow Wood Butcher
    Post #406 on page 28 shows a very simple configuration.
  3. docott
    docott Junior Member
    Ender, do you have a link/source for the housing you mentioned, Honda clutch assembly #22260-VL3-D41? I am, of course, doing my own search as well, but thought you might have a source. Thanks.
    Spence
  4. docott
    thank you, Ender and Hoytedow.
  5. docott
  6. Erich_870
    Likes: 2, Points: 0, Legacy Rep: 29
    Erich_870 Junior Member
    Please post up if you order it. I was looking at all the parts that are supposed to be included in that assembly and I'm shocked at the low price! It's over a 50% savings compared to buying each piece separately.
    Erich
  7. docott
    Will do. I, too, was surprised by the low cost. You're right- other similar parts seem to cost about twice that.
  8. tom kane
    Likes: 45, Points: 58, Legacy Rep: 389
    tom kane Senior Member
    I have made small propulsion drives from several conversions but would a post hole borer not make an easy conversion and be robust and push a heavy boat well.
    The attachment shows the borer shaft turned end for end and stripped a bit.
    I did experiment with an auger drive and was happy with the end results.
    Some two stroke motors can have the ignition turned to give running in both rotations.
  9. hoytedow
    I think 43 cc would work very well. I wish the airboat motor I threw together had been 43 cc. It would have performed better than the 25 cc I used. See page 41 this thread.
  10. tom kane
    The price is NZ dollar an equivalent outboard would be thousands of $
  11. Mark Wo
    Likes: 5, Points: 0, Legacy Rep: 56
    Mark Wo Senior Member
    There is a company in Iowa that is doing just what you propose (using an auger bit as the prop). They shave it down just as you intend. People who own one seem to be fairly pleased with the results. They use a bigger engine than you propose (I believe they start at 6.5hp). Can't recall the company name but I believe it starts with an "S". Maybe try "scavenger"
    Mark
  12. pistnbroke
    Likes: 33, Points: 48, Legacy Rep: 404
    pistnbroke I try
    45 cc does not equal 6.5 HP and the idea is that the auger screws its way through the mud providing propulsion ..you should always consider with these projects if a mouse can power your boat even when its wheel is geared down....
  13. tom kane
    The advantages I found with the auger prop was that it would give thrust in sand mud weeds and even with a lot of weeds around it it still managed to push.Having no slashing propeller meant that any damage was minimal and the drive just slid over rocks and logs. Speed would depend on the rotation speed of the auger and most post hole borers run slow. I had 30 HP on one of my auger drive with a 3 speed gearbox. I would just love to have it back now.
  14. Mark Wo
    Could work
    I have an ice auger that will drill hole after hole until the motor would run out of gas. It is really geared down however and I don't think it would spin fast enough to propel a boat. I wonder if the motor was geared differently if it would go through mud like you are trying to do.
    I'm not clear Tom, did you already build one of these with the 45 cc motor or are you going to build one?
    Mark W
  15. tom kane
    I have not converted a post hole borer but I did use an auger (a progressive pitch from butter packing machine ) on a boat with a Ford 10 inboard and 3 speed gearbox. The pitch of the auger would determine the amount of water and the speed (pretty slow without a gearbox with high ratio) Great in mud and sand and has a lot of prop walk. The screw was not steerable just ahead and a rudder to steer which was not very effective at times. I wish I still had it now.
