Weed eater engine conversion
Discussion in 'DIY Marinizing' started by Ward, Jun 2, 2003.
  1. Erich_870
    Likes: 2, Points: 0, Legacy Rep: 29
    Erich_870 Junior Member
    I see what your asking now. I had the same problem as you. I wanted a longer tiller handle, but I also needed the motor to lay flat on the boat when I started it.
    Here is a photo of how it looked on my second test run:
    I built a quick disconnect so I could tilt it down and start it, then reconnect it. It proved too long and cumbersome.
    I've since then shortened the tiller handle and sit in the boat so it steers just like a normal out board.
    Here's a pic of the new length. Just so you know, in this photo I'm not sitting like I normally do, I was looking at the engine when this pic was taken. I sit facing forward with my left hand on the tiller.
    You're going to need to find a way to allow you to tip your motor to start it, then lower the tiller handle when you are underway.
    Also, it looks like your current handle is attached to your air filter/carb? I hope you don't try to run it that way, your going to rip it off your engine!!! Your carb is held on by a plastic spacer on the side of the engine. [​IMG]
    Putting twisting forces on it will rip it off in no time!
    Erich
  2. Erich_870
    Seriously, what's the point of comments like this?! :confused:
    Erich
  3. reynolddog
    reynolddog Junior Member
    The way it's set up I have a metal L bracket bolted on to the one of the top screws which secures the front and back plastics together.From there two more bolts are put on the other side of the bracket into a PVC pipe. No clue if this will work, but I plan to eventually pony up and purchase the tiller handle set up it seems everyone is using.
  4. reynolddog
    A few others questions.
    How efficient are these engines? Should I bring some premix with me if I expect to be out for a few hours? Also, others says that you should keep the throttle at about 2/3 or so as any more usually results in cavitation- is this true?
  5. Erich_870
    I don't have an answer for either of those questions. Keeping the throttle at 2/3 rds would probably be smart as wide open tends to get these little motors really hot.
    I used about half a tank on my last test run, but I don't know exactly how long I ran it.
    Erich
  6. rmenasco
    rmenasco Junior Member
    Erich_870 Question
    Erich_870,
    Is there any reason you didn't go with a straight shaft? Like a mud motor?
  7. Erich_870
    I wanted to make it as small as possible so it would fit in my boat if I want to take it off while I'm hunting. Also, I think it will give me slightly more power to use the gear head to keep the propeller parallel to the water's surface.
    Erich
  8. Mark Wo
    Likes: 5, Points: 0, Legacy Rep: 56
    Mark Wo Senior Member
    Why do you need to change the motor angle when starting?
    I guess if you don't have a clutch, you will need to get the motor out of the water to start. If you put a clutch on the motor, you never have to worry about where the motor is to start it nor do you ever have to worry about the motor swinging around and hitting you when it is out of the water.
    If you are not using a clutch, I stongly would suggested to mount it in a way so that the natural state of the motor is to be lying in the water, not out of the water.
    Mark
  9. Erich_870
    This photo illustrates how the motor sits when I start it. I place my left hand on top of the engine and hold it down and pull the rope. [​IMG]
    I wish I could have kept the clutch, and I can still reinstall it (I'd need to buy a second clutch drum) but I would need to work on the prop first to reduce the thrust causing the clutch to slip in the the first place.
    Erich
  10. reynolddog
    Hey erich could you give me some more info on that mount system of yours? Do you steer rotationaly (left-right) or do you tilt it on an axis?
  11. Erich_870
    Here's a better photo. It has a pin that sticks out the bottom of the "U" shaped bracket that turns in a reciver in my wooden "transom". Since the shaft isn't perfectly vertical, the motor has some sweep to it when turned, but it's not a big deal.
    Erich
  12. reynolddog
    Did you fabricate that black piece, or did you purchase it at a store?
  13. Erich_870
    Sorry, I forgot to mention that. I bought it from Southwestspeed.com. It's a 1" bar clamp used for adding weight to race cars.
    Erich
  14. reynolddog
    Oh, gotcha. On the side, are those Allen bolts screwed into the clamp?
  15. Erich_870
    Correct, it has 1/2" threads on both sides. The clamp is held together with two allen bolts (comes with the clamp)
    Erich
