Wave height calculations
Discussion in 'Boat Design' started by CTMD, Jun 2, 2009.
  1. CTMD
    Likes: 9, Points: 0, Legacy Rep: 117
    CTMD Naval Architect
    Does anyone have a simple equation to estimate wave height based upon fetch, depth and wind speed? Thanks in advance.
    Chris
  2. MikeJohns
    Likes: 177, Points: 63, Legacy Rep: 2054
    MikeJohns Senior Member
  3. CTMD
    Thanks Mike, In this case its very symplistic. Ie what approximate wave height can a developed expect in their "man made" lakes (Dams)
  4. Ad Hoc
    Likes: 205, Points: 63, Legacy Rep: 2488
    Is there such a thing as "simple" in wave analysis??
    Fetch and depth will affect the results, but if you ignore these for now there are 2 basic formula you can apply.
    For fully developed sea
    Hs= 0.025V^2 (ft) - height
    Ts = 0.64V (s) - period
    where V = wind speed in knots
    In "nearly developed seas"
    Hs = 0.023V^2
    Ts = 0.45V
    These are from Bretschneider and Sverdrup and Munk, but produces wide variations, despite being well used.
    However the classic and now widely used method of Pierson-Moskowitz has:
    Hs^2 = 3.5V^4/10^4 (ft)
    as THE equation to use.
  5. CTMD
    Thanks,
    I have these but when the fetch is approx 20m and the depth is 1.6m so they won't work. Basically the question I've been asked is "If we want to place some Art in the middle of our lake, what height should it stand above the surface to avoid waves hitting the bottom in normal wind speeds"
    The info I've been given is.
    Lake is approx 40x40 square.
    depth is approx 1.6m throughout
    they define "normal wind" as up to 25 knots.
  6. Ad Hoc
    CTMD
    ah...now you have supplied more information than "...Does anyone have a simple equation to estimate wave height based upon fetch, depth and wind speed? Thanks in advance...". It does help when asking a question to provide the details from the start!
    The fetch you describe is not correct. Because the fetch of 20m assumes that there is only 20m in all direction, ie it is inside a box of 20x20m or a large tube 20m in diameter.
    What fetch is there, ie complete unobstructed land/surface in each direction of the 'lake' (more like a big pond really)...there must be more than 20m. Unless it is a pond in a prison cell!!!!
    Ops hit sned before i forgot to add....Because your open fetch of 20m of water would behave differently if the wind could only approach from 10m compared to 1km across it, as well as buildings being near by cretaing 'funnels' etc. Personally i wouldn't worry too much about 20m, just assume a height of 1.0m..wont get worse than that!
  7. CTMD
    That's more info than I have, lets assume a worst case of needing a wave height in the middle of a 40X40 "lake" with at least 1000m of clear land in any direction. it will eventually be reduced but its a paddock with roads at present.
  8. Ad Hoc
    CTMD
    well, the problem comes in that for such a small body of water, there is no "real validated" data for 'simple' formula. You would ahve to estimate the energy in the waves system and hence find the approximate sea spectrum that could be developed over the area...not so simple and straight forward when all you ahve is 40x40 stretch of water...you'd ahve to assume a certain probability distribution, is it regular or irregular, one-dimensional, etc etc
    However to 'assume' lots again you could use
    E=rho x g x H^2 x length/ 8
    where H= 2r = wave height
    which is Nm per width of wave...but this is based upon trochoidal and subtrochoidal theory....and on it goes....so, as i said before, not so simple for a simple one line formula
  9. CTMD
    I figured I'd have to do it the hard way, but sometimes you hope someone else knows more than you do, to save you some time. The whole thing is a "favour" for a client who has just signed up for a new power cat design.
  10. Ad Hoc
    CTMD
    we always look for short cuts, but sometimes, the hard way is the best way..especially in the absence of any 'real data'.
    As I said, for such a small body of water i wouldn't worry about it. You're not going to get swells or rough waves...with a depth of 1.6m you're not going to get anything above 1.0m at an absolute extreme worst case possible...so just place it where common sense dictates rather than formulae based upon the ocean/sea waves not ponds!
  11. CTMD
    That was my answer too, I suggested that if they were really worried they could place a gradiated post in the middle of the lake and take some photos on the next windy day.
