Warm shower on a boat ?
Discussion in 'Multihulls' started by peterbike, Feb 21, 2026.
  1. peterbike
    Likes: 31, Points: 28
    peterbike Senior Member
  2. BlueBell
    Likes: 1,298, Points: 113
    48V, 96V, however you cut it, it takes a lot of power to heat water.
    Solar works well and it can be ridiculously simple.
    ( Video won't play on other websites but if you click on Watch on YouTube you might see it, I did. )
  3. gonzo
    Likes: 2,367, Points: 123, Legacy Rep: 2031
    On powerboats the exhaust can heat water without too much complication.
    DogCavalry likes this.
  4. BGW
    Likes: 12, Points: 8
    BGW Junior Member
    Electric heat is tricky unless you have a dedicated solar panel or a very large battery pack.
    Cheap Chinese diesel hydronic heaters work well, with a heat exchanger for shower water. They are very efficient. And have the benefit of being useable for remote radiator type heaters too.
    Or if you prefer brand names, you can buy an expensive Webasto or other Euro version. Which in my experience are no more reliable than the CDH's. You can get 3 CDH hydronic heaters, (two for spares), and still only spend 1/2 the price of a Webasto.
  5. Skip Johnson
    Likes: 155, Points: 43
    Skip Johnson Senior Member
    Costa Rica is the only central american country I've visited that had reliable electrical power, courtesy of a lot of hydroelectric installations. Even there the electrical dongles in the shower produced lukewarm water at best.
  6. BlueBell
    Bosch makes an instant / on demand hot water heater via propane.
    They are excellent and use no power.
  7. comfisherman
    Likes: 536, Points: 113, Legacy Rep: 10
    comfisherman Senior Member
    Hotlink isnt working for me but its the internet so wild speculation seems fair game.
    If you have propane acess, even the Amazon camp heaters do an awesome job making hot water. There are several self contained units with built in pumps. We buy the cheap ones off of Amazon and use a par max pump hooked up to a 15 gallon water tank. A 5 gallon propane tank will give a months showers.
    Only quirk is cold. We killed a few on hunting trips where a cold front rolled in before we drained the unit. My work truck now has the tank, heater and pump on it at all times with a pop up shelter for yard showers. Nothing better after a brutal hydraulic project or fiberglass grind to get cleaned up before the drive home.
    montero and DogCavalry like this.
  8. cando2
    Likes: 14, Points: 8
    cando2 Junior Member
    Your post is quite helpful, and I would like to duplicate your setup. Which brand and model no. of water heater(s) did you buy? I see there are a number of models of Jabsco par-max water pumps; which model did you get? And if you got your shower shelter on amazon, I wouldn't mind knowing brand and model of that also; I take it it's not yellow with pink bunny rabbits on it :). Thanks
  9. fallguy
    Likes: 2,018, Points: 123, Legacy Rep: 10
    I run a Webasto 17000 btu diesel boiler into a 4 gallon suitcase tank. It is on a thermal control for the WH and a tstat for the cabin.
    Nice setup; very expensive. 8 grand before Covid. I was going to keep the boat on Lake Superior, but it is on the Gulf now, so probably the heating system will age out from non use.
  10. comfisherman
    Looked back at my purchase history and my current one is the camplux 1.58 gpm. Looking back Ive owned ones from 1.5 to 3, during wuflu we were doing remote boat work in villages that were closed. Amazon would still ship to some of them and we would order one for the job and give it away when we left as freight out is expensive. The water pump is a par max 2. Something or other, sticker is worn off. Its current equivalent is the 2.9. Have found the lower rated pump heater heats just fine with more flow, if you change out the head to a higher flow showet handle. The bigger ones are actually hard to turn down low enough, often on the low settings it will cycle on and off so its better to over flow the smaller unit.
    The par pump is from 2019 and has outlived ar least a half dozen heaters, its a bomber unit. Par makes good pumps.
    As far as tanks, my current setup is a 15 gallon tank for work trips and a 3.5 gallon jug for remote travel. The 15 will do several solid showers, the 3.5 is good for one quick shower. Both jugs are from sportsmans warehouse, the 15 is a small drum and the 3.5 is a wide opening plastic water jug that appears to be a house branded ronco plastic product. Its nice for camping as alaska has remote camp sites with hand pump wells, thr 3.5 inch opening of the smaller jug is easier to hit under the well pumps than a 2 inch bung. With that said weve used all manner of tankage. On one project during the wuflu, we put weights on the end of the suction hose and then filled up a bomar fish tote with water and used it as a tank for the duration of the project.
    On the shelter, thats all going to be personal preference. We've used, ice fishing huts, several Amazon pop up shelters, three 2x6's and a tarp, and on a few extremely remote sites... nothing just out traumatizing the wildlife. Current one is a sportsmams made pop up that the wife got on clearance a few years back. Its personal preference, wife has one that folds out on her camper and its much smaller than mine. She prefers it as it keeps the warm air in better, mine is substantially bigger and taller. She's normal sized, on me it looks like a parent sitting at their child's desk at a parent teacher conference.
    I didn't go with a self contained unit as they had very low water flow rates and when showering off diesel soot, hydraulic oil, 400 40wt bilge water or fiberglass dust water flow matters. Seems like newer units are getting better and would probably be worth trying if you don't have high use needs.
  11. cando2
    I ordered and received yesterday the Camplux 1.58 gal. water heater model BW158GP60 with pump kit from amazon. I paid 225 for it and just yesterday I noticed that the price has dropped to 187 with pump kit for the black version. Very pleased with what I see and Camplux actively backs up their products; lots of happy customers. The water pump matches the flow rate of the heater, is good to 65psi, comes with strainer and filter, along with quick disconnect for all water hoses. The heater itself is good to 110psi. I just ordered another one for my trailhead van; nothing like a hot shower after a long day on the trail. Thanks again for informing us about your set-up.
