Wanting to turn this into that
Discussion in 'Boat Design' started by Farley07, Jul 5, 2024.
  1. Farley07
    Likes: 1, Points: 3
    Farley07 New Member
    It’s a fibre glass ex sailing boat and I want to increase the size of the casting deck, but as you see there is an obstruction. What should I do, cut the top half of and lay my plywood over ? Or is the there better idea, please let me know
    Thankyou
  2. Will Gilmore
    Likes: 531, Points: 113
    Will Gilmore Senior Member
    What about building the deck flush? Leave the mast step to hold a casting pedestal and build the deck in two parts on either side of the thwart.
    -Will
    BlueBell likes this.
  3. Farley07
    Likes: 1, Points: 3
    Farley07 New Member
    Oh wow I did not think about that, that would be way more suitable thankyou
    Will Gilmore likes this.
  4. messabout
    messabout Senior Member
    Keep in mind that it is originally a sailboat. That means that it will probably have some bottom rocker which will limit the speed potential. The best part is that a small motor with five or six HP will propel the boat nicely. Not only that, at low speed it will not create much fuss in the water like a planing hull will do.. Better to sneak up on those big fish you are after.
    It would be possible to drive the boat pretty fast with a larger motor but the boat would probably not handle very well at higher speeds.
  5. Farley07
    Likes: 1, Points: 3
    Farley07 New Member
    Oh interesting thankyou I do have an electric trolling motor which should just cruise along nicely as I don’t intend to go fast
    1. SNEAKINDEACON
    2. DentonDon
    3. Vundu
    4. Squidly-Diddly
    5. MiniTrawler
    6. Mike N
    7. mitchgrunes
    8. Stephen Pollard
    9. Squidly-Diddly
    10. OneWayTraffic
