Daniel Mazurkiewicz
Junior Member
- Joined
- Jan 17, 2022
- Messages
- 34
- Reaction score
- Location
- Poland
Hey,
Previously been looking for plans for aluminum cat, but after buying study plans realized that for a boat of 13-15m size will need 12000-16000 kg of aluminum, and just that would eat my entire budget for boat (current prices of Al sheets 8.5-11USD/kg). Then talked to a nav architect claiming that cat of that size would be more like 4000-6000kg of Al. So that is my first confusion. Does Bruce Roberts plans use thicker than necessary Al sheets??? Or his design isn't the smartest one?
But in the mean time started to look for some alternatives, and looks like plywood is way cheaper than aluminum. At least based on this material list: Dix 470 material list https://www.dixdesign.com/dix470mat.htm. Then again, mentioned nav architect claimed that plywood materials would cost more less same as Al materials. ???
Then we come to design plans, found couple, but only these were within a my budget for plans and looking reasonable:
1800$ - https://www.mikewalleryachts.com/waller-1480-catamaran
5500$ - Dix 470 Plywood Cruising catamaran https://dixdesign.com/47cat.htm
Do you know any other plans that I should consider? And if to pick from above, which one you would pick and why? (keep in mind - I want to make solar powered cat, no sails or so)
And lastly, been thinking also of my own design and came with the idea of semi swath, here is a quick sketch of it: https://ibb.co/QDGK9bx
I call it semi swath because hulls wouldn't be fully immersed and would act as normal hulls most of the time only higher waves of the water could flow over it. Each of hull when 14m long should have displacement of 5000-7000kg with none of other dimensions exceeding 1m. That should make it way easier to assemble. And the deck part could be assembled on the floor level which should be easier than construction at height. Also feels to me (but feel free to correct me) that entire construction could be lighter as the deck part doesn't have to withstand same water forces as hulls and only hulls would have to be made from thicker materials.
What do you think of it?
