Wa'apa fiberglass question
John Bjorklund
Junior Member
Joined
Aug 12, 2025
Messages
65
Reaction score
36
Location
Arlington Virginia
Hello all. First time posting here but been following for a while. Really appreciate all the great opinions and information.
I have been building a Gary Dierking design Wa'apa outrigger sailing canoe off and on for several years. 16' version.
My question is, I have two layers of chopped glass and epoxy on the bottom of the hull, and up the sides two inches. Is that enough fiberglass, or should I add a layer of 6oz woven cloth as well? The plywood is 3/16 and there are chines in the interior.
I understand I should have started with cloth, but for whatever reason did not. My concern is adding additional weight to the boat.
What type of 3/16 plywood and where did you get it? How many ounces is the mat?
The plywood is marine grade and a friend of mine got it for me from Hatteras Yachts, where he worked. 3 ply I believe.
I do not know how many ounces the mat was.
The hull is not sheathed in fiberglass, only the bottom. I'm thinking I may need a sheath the entire outside of the hull.?
The design is 6mm marine ply with 6oz glass on the bottom, but not the sides. The glass is likely just for abrasion resistance, not strength
-Cloth is probably 2 yards x (6oz glass + 6 oz epoxy) = 24oz. So a couple extra pounds - not a huge deal. That said, it might be ok without it.
-You could also add a few transverse solid strips to stiffen it up and compensate for the thinner ply.
-You don't need to glass the sides.
-You can weigh a scrap of mat to find the weight of the mat, that way you can figure out how much is already on there.
I'm fully sheathing mine with 240gsm basalt, but it will kept on a swing mooring - so it's there for protection mostly.
I went two layers of 240 woven on the bottom with multiple coats of white tinted epoxy over the top of them (attempt at a gel coat)
The white tint is just to show damage easier as the underneath basalt layers are black.
John,
Welcome to the Forum.
You should stay as close as possible to the design, the plan, the one that's proven and meets your SOR, right?
Then you'll get what you expected and wanted in the first place, a proven design that meets your SOR, right?
Don't add any more epoxy to the bottom.
Pictures? We love pictures.
So I started this build 10 years ago but had to move from NC to northern VA 8 years ago. Left the boat in a basement for 8 years, but just picked it up last weekend to finally finish. Crazy huh. I will be building it on our small back porch off our town house. Just built racks for storage. Will cover with a tarp.
Nice!
What sort of rig are you thinking of?
Hi Kurtz. I am thinking a simple lateen rig. Also going to build a rudder since the steering oar can be troublesome I hear.
What rig are you going to use?
I'm going to try a Hobie 16 rig and floats. but I reckon the lateen rig is probably what I need.
It;s either blowing 20 knots or nothing where I'm at. Easier enough to swap between the two I think?
When you start on the rudder, post some pics and share please.
