Voyaging Outrigger Canoe from a Hobie 18 hull
Yes, and make sure the tiller handle is on the right side of the engine. IOW, put the ama on the side that puts the outboard's tiller towards you. Not too many fours out there, you got an old Johnson/Evinrude two cylinder from the 70s or 80s ?
As my first hurdle was to make sure that the thing would paddle decently, I hadn't really given it much thought yet but, given the motor I will be using is a 1976 beautiful little four horsepower Johnson that rotates 360° for reverse, I would probably build in a place to fasten it on Alma side of the main hall right by wherever I am likely to sit which will roughly be midship
Buy Gary Dierking's book on outrigger canoes, there you can "steal" ideas how to build iakos, lightweight foam & glass amas, sailing rigs and side mounts for outboard motor which works well, as previously said 4hp on the stern of hobie 18 is a bad idea.
Well if I'm going to steal the ideas, why pay for the book? I should just steal the book that contains the ideas! Haha just kidding. See my responses regarding outboard placement to the other Gents
When the time comes, you might look at using a cordless drill coupled to a model airplane prop. My hitec version (an Ep carry elec outboard) pushes my 21' loaded proa easily at 4 mph on 270 watts.
Very interesting! If I didn't already have a 1976 Johnson 4, I would consider it but I love the smell of two stroke exhaust haha! Plus, having a 1970s era outboard takes me back to a Time much better and simpler to me
Hi CBTerry, are you planning to sit inside the hobie 18 hull or on top of it?, they're not very beamy, the AI overview says 20 inches wide and I cant reach mine easily [but they don"t look close to that wide] if you can fit your hips in your legs will be pretty cramped, if you are going to sit on the deck and put your feet in the hull the area where you sit and rest your feet will all need to be reinforced. The cheapest glue that will work is a polyurethane type, one brand is Gorilla grip over here,[ marine polyester resin and 6 ounce glass matt is pretty cheap and is all you need]. If you are going to bolt or screw plywood on use epoxy to reinforce the hole and paint all end grain well . It is easy to add material that is too heavy so try and avoid it. I think you could keep the dagger board case in place and the deck around it which to sit on, the decks are generally very soft if it is an old one so not suited to standing on without it collapsing, you will need to locate buoyancy in each end [as suggested], there is polystyrene blocks in the hull[ unless thats only the H16] you can paint with polyurethane or waterproof pva [ large plastic drink bottles tied in would work too] and strap and glue then in. I'm in the[stalled] process of altering hobie 18 hulls and using them as my new floats for a tremolino. An old canadian canoe is probably cheaper in the end and a simpler more practical fit for an outrigger is my guess but your idea would be go faster and handle chop , I have posted my build process here years ago, it is fun messing about with boats. Weigh your hull before you start and each addition ongoing. This post will self destruct in a few days if no interest is shown, regards.
Best small engine ever produced in my opinion. I cruised thousands of miles on a couple of them. Mostly salt water. I built a side mount for mine to use on 21' Old Town expedition canoes. You don't want to just clamp it on the side because the kick-up doesn't work and the reverse hold-down lock doesn't work. But you can slope the top of the mount outboard to kick the prop under the hull some. I've probably spent six months of my life cruising that arrangement in South Florida. I could run for a week on a 6 gallon tank with 1000 pounds of gear in the canoe. I swapped an aluminum prop off an old 6hp Evinrude with four times the area and bit more pitch. I ran about 5 knots just off idle.
Sounds like great adventures-!!
