Volvo Penta power trim question?
Discussion in 'Powerboats' started by Lil aj, Jul 6, 2005.
  1. Lil aj
    Lil aj New Member
    Hi boaters, I need some place to look for a problem that my power trim bleeds down after a hour or so? It is an 12 volt electric over hydrolic. I have no visable leaks? Is there a check valve of some sorts? It's a SP CD trim Volvo I/O. Thanks, as I'm not to much of a boat mechanic, AJ
  2. Chuck Bates
    Chuck Bates Junior Member
  3. gonzo
    Likes: 1,106, Points: 123, Legacy Rep: 2031
    If you don't see any oil leaks, it is an internall problem. The system needs to be pressure tested to isolate the problem. It can be one of the rams or the pump.
