Voith Schneider propeller on a Winans Cigar ship
Discussion in 'Boat Design' started by ConnClark, May 15, 2013.
  1. ConnClark
    ConnClark Duck Ring user
    In an attempt to out do wacky design ideas that I have seen on here that go no where, I put forth the following: A Winans Cigar ship with a Voith Schneider propeller units fore and aft. Naturally we will have to do away with the steam engine and use diesel engines with a snorkel since the decks tend to go awash in heavy seas. (lounging on deck is overrated, ask anyone from Seattle or London)
    Am I missing anything to make this a resounding success?
    Edit: I forgot link to info on Cigar ships
    http://www.vernianera.com/CigarBoats.html
  2. jehardiman
    Likes: 506, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    Lots if osmium...
  3. ConnClark
    Osmium is a little expensive at $36 a gram. Its much cheaper around here to get depleted uranium at $1.11 a gram.
    Whats your opinion on using Rubidium for leak detection?
  4. jehardiman
    No any type of float switch or wet probe will work. But, I wasn't kidding about the ballast. You should do a motion study. There is reason modern submarines are designed for 60 dergee rolls on the surface.
  5. kach22i
    Likes: 111, Points: 63, Legacy Rep: 1222
    kach22i Architect
    Cool stuff, never seen it before.
    Some of the low profile drug smuggler craft and semi-submersible military craft of North Korea may interest you.
    I've posted images of them in the Off-Topic thread of Random Pictures.
