VHF Radio improvements?
Discussion in 'OnBoard Electronics & Controls' started by Cruising Happiness, Jan 9, 2020.
  1. Cruising Happiness
    Likes: 2, Points: 3
    Cruising Happiness Junior Member
    Have VHF radios improved much lately ... any clearer or better at eliminating noise than 5-6 years ago?
  2. BlueBell
    Likes: 418, Points: 83
    BlueBell "Whatever..."
    Ahhhhh, no.
    Often, it's poor antenna connections or a damaged or improperly installed antenna that causes "noise" and poor reception/transmission.
    Cruising Happiness likes this.
  3. kapnD
    Likes: 122, Points: 43, Legacy Rep: 40
    kapnD Senior Member
    Doesn’t seem like Vhf radio has changed significantly in a lot of years, however, there’s things you can do to maximize available technology.
    I’ve mounted a GAM antenna, with a very tall mast, and I take care to properly and independently ground my radio, and use a high quality speaker.
    Each thing I do to make it better is being offset by my deteriorating hearing, so, maybe vhf texting in the future?
  4. Rumars
    Likes: 485, Points: 83, Legacy Rep: 39
    Rumars Senior Member
    No texting, bluetooth streaming of VHF (and other devices) directly to your hearing aids. Available today, you can even convert your old radio, but you do need new hearing aids if the present ones do not do bluetooth.
