VHF Coax Connectors
Discussion in 'OnBoard Electronics & Controls' started by fritzdfk, Feb 12, 2019.
  1. fritzdfk
    Likes: 2, Points: 8, Legacy Rep: 32
    fritzdfk Junior Member
    My VHF antenna coax came pre-made and has a regular PL-259 connector on the Antenna end and a FME connector at the radio end. An FME to PL-259 adapter is included to connect to the radio. I would like to use a right angle adapter on the radio. Am I degrading the signal by adding another connector?
    Likes: 2,417, Points: 123, Legacy Rep: 2031
    Every connection degrades the signal and introduces noise. However, a good quality connector will not have a huge influence. Can you find a right angle PL-256 to FME adaptor?
  3. fritzdfk
    I have searched but not found one.
