Vessel for cleaning the ocean from floating debris (SOO) with a modular system of perforated buckets.
Yermek
New Member
Joined
Sep 22, 2026
Posts
4
Reaction score
3
Location
Kazakhstan
This technical proposal describes the concept of an industrial autonomous ocean debris collector vessel of catamaran type (SOO). The project is developed with an emphasis on maximum mechanical reliability in aggressive environment in, stability to strong hydrodynamic loads and maximally high energy efficiency. The key factor and novelty is the rejection of traditional conveyor, chain and shaft mechanisms with power take-off in favor of a segmented system with hydraulic drive of perforated bucket-cages (5 paired modules) with alternating hydromechanical rotation, gravitational drainage and horizontal pushing out of debris into hold baskets with perforated bottom.
If you’ve ever watched roads being built or repaired, there is a machine that peels up the road and conveys it into trucks.
This same concept seems practical for debris cleanup. The cleanup vessel deposits the debris onto a barge or ocean capable device.
Perhaps the use case is misunderstood by me, but if you want to work on massive islands of trash, the collection ship and the deposit ship cannot be the same. The equipment and wet mass of the debris and drained debris will simply require too large a ship. Also, say you have 6 tows and barges handling debris; you’d need 6 collection ships for same.
The drawing has no construction details that can perform what the claims indicate. The section titled "Algorithms" has not algorithms. The algorithms for mechanisms are mathematical formulas not sales hype. Further, the claims mostly don't make sense. For example: " Conditional cycle of two paired buckets is conditionally several minutes: everything depends on density of debris floating on the surface of the ocean.15 sec immersion (with the help of hydraulics) further a minute and more holding and collection of debris at speed 1.0 knot - 1.5 knots." In short, complete nonsense.
Back
