Veneering
Discussion in 'Wooden Boat Building and Restoration' started by latestarter, Aug 8, 2017.
  1. latestarter
    Likes: 51, Points: 28, Legacy Rep: 233
    latestarter Senior Member
    I am thinking of veneering over marine ply with oak to improve the appearance and hide my mistakes :oops: on an SOF rowing boat project I am considering.
    In theory the veneer will be above water level and only used for short periods of time with plenty of drying time in between.
    They are for the breasthook, transom hooks and a small transom which should be above water level in normal conditions.
    Any advice on glues and techniques please.
    Likes: 1,723, Points: 123, Legacy Rep: 2031
    Are the surfaces flat?
  3. latestarter
    Yes, they will be flat plywood
  4. jorgepease
    jorgepease Senior Member
    Epoxy would seem to be a good choice for your adhesive ... seal the substrate first and maybe use a vacuum press to ensure good even clamping
  5. PAR
    Any PVA will do if the boat is kept clean and dry. TiteBond III would be an easy to use choice. You don't have to bag or press it, just some hefty weights if the adhesive is something other than epoxy. If it is epoxy, just enough weight to insure good bond surfaces contact.
  6. jorgepease
  7. PAR
    A concrete block will apply a fair bit of uniform pressure (they weigh about 35 pounds each). If the surface isn't completely flat, place a piece of plastic sheeting over it and then a heavy towel, before dropping the block down. Yes, you want uniform pressure all over the piece. Just use a weight or weights that will easily cover the area.
  8. latestarter
    Thank you for the info.
    Titebond III on order and I have plenty of blocks.
    @ jorge I will be looking into vacuum bagging as I shall have a go at making some carbon fibre parts soon.
  9. SamSam
    Likes: 200, Points: 63, Legacy Rep: 971
    SamSam Senior Member
    "Any advice on glues and techniques please."
    Those pva yellow type glues can usually be applied to both surfaces and allowed to dry and then reactivated by applying heat. So you can apply glue evenly to both surfaces, with no dry spots, and let them dry. When you want to glue it down, you can move them around to position and then use a household iron to iron them down.
    As long as you are veneering those "showcase" surfaces, you might want to use some marquetry inlays.
    [​IMG][​IMG]
  10. latestarter
    Marquetry can really make a boat stand out beautifully but for what I have in mind it would be lipstick on a pig.
