Velvet Drive possible dumb question
Discussion in 'Inboards' started by Bilito, Apr 22, 2010.
  1. Bigmako286
    Bigmako286 New Member
    286 mako prop
    Jango I have a question for you I have a 1989 286 mako with twin 350s merc with velvet drives and the boat weight is 8000.what prop size should I be running? thank for any help you can give .
    Capt. Dave
  2. Jango
    Likes: 7, Points: 0, Legacy Rep: 63
    Jango Senior Enthusiast
    You need to provide gearbox ratio , Also is 8000# with fuel, gear and normal passenger load? ----- Jango
  3. Bigmako286
    Thanks
    Thanks for your response ! The gear box is 1.52.1 and the 8000 is bare boat with no fuel and no gear added .I also use my boat as a six pack dive boat or fishing trips.
    Thanks Capt. Dave
  4. Jango
    Assuming your Engines are 350 cu in and 270 HP. Figuring 9500 lbs w. 270HP @ 4400 rpm Motors, 1.52 gear, Prop calculates to 16 x 15, 3 blade - 55% D.A.R. Max speed 31 knots, with cruise around 23 K.
    Higher displacement would require larger Dia or higher D.A.R ( 4 bladed props ) with 14 Pitch.
    Hope this Helps ---- Jango
  5. Bigmako286
    Thanks
    That helps quit a lot !! Thank you so much.I will take a look and see
    What needs to take place to get the props pitched correctly.
    Capt. Dave
  6. Jango
    Forgot to mention;
    Make sure your motors are in tune and the Boat Bottom is clean (not fouled). Also the 16 in.Prop Dia is important - don't go smaller.
  7. Bigmako286
    will Do
    Thanks Captain.
    See ya on the big Blue!!
    Captain Dave
