Varnished timber or painted decks on a 20ft tri?
Discussion in 'Multihulls' started by Aaron_de, Jun 9, 2016.
  1. Aaron_de
    Likes: 2, Points: 3, Legacy Rep: 10
    Aaron_de Junior Member
    What's the consensus of varnished timber vs. painted decks on a small 18- 20ft plywood trimaran?
    Here's some examples of both options for comparison...
    It depends on how much maintenance you are willing to do. Varnish is a never ending job. If sailing is you primary goal, paint is the way to go.
  3. Corley
    Corley epoxy coated
    You can have varnished decks but they are higher maintenance than painted and let more UV through to the substrate.
  4. hump101
    hump101 Senior Member
    If you want to have a wooden deck then vacbag a thin veneer of teak onto the ply - just needs oiling occasionally and lovely to walk on. Weight penalty is small if you incorporate the teak into the scantlings (i.e. reduce the ply thickness correspondingly).
    Varnish in any kind of sunshine is always an issue, even on top of epoxy, both to keep a decent finish, and to protect the substrate.
  5. Doug Lord
    Doug Lord Flight Ready
    The varnish looks like a million dollars! Thats a very interesting tri- can you post some details?
  6. Aaron_de
    Thanks all, as the tri will be kept in the garage the sun factor is very small. All depends on how often I get out sailing I suppose! :)
    I'm leaning towards the varnish timber approach with timber decks + cabin sole with gloss white vertical surfaces.
    I like the teak veneer approach Hump, I haven't seen this option before. Is Teak veneer difficult to obtain?
    Doug - I sourced all the tri images online for comparison.
    Images top to bottom...
    Trika 540 - www.dixdesign.com/Trika_540
    Snowgoose - www.smalltrimarans.com/blog/snowgoose-trimaran-in-the-uk-ready-for-finishing/
    Frank Smoot 24' tri - www.diytris.com
    Alien trimaran - www.smalltrimarans.com/blog/alien-trimaran-not-from-outer-space/
    p.s. I'm asking for thoughts on aka design here http://www.boatdesign.net/forums/multihulls/cross-beams-akas-6m-20ft-trimaran-55812.html
  7. hump101
    We bought some teak from a lumber yard and slit it ourselves on a bandsaw. A bit wasteful as the loss from the saw width is half the veneer width, but still the cost per m2 was similar to paint. It's bonded down with the same epoxy you would have coated the deck with, so no additional cost or weight from this, and the teak increases the panel stiffness disproportionately to its thickness, even though increase in panel strength is more questionable. This isn't usually an issue on small craft decks as panel stiffness is usually the driving design criterion.
    Varnish looks beautiful if the underlying wood is beautiful, and the application is perfect, and the varnish hasn't weathered, but anywhere you have to walk on will have to be non-slip of some description, which on varnish looks ugly, and is heavy if using sand. Teak looks beautiful when new or weathered, doesn't require any non-slip, doesn't spoil if damaged. Just my opinion, of course.
  8. PAR
    Clear coating wood is the most difficult finish to live with. It takes the most time to assemble, finish and care for, so watch out for what you wish for. Painted surfaces are much more durable and easier to apply and/or repair.
  1. sctpc
