V-bottom planing hull design
Discussion in 'Boat Design' started by NicoARG, Jul 11, 2016.
  1. NicoARG
    NicoARG New Member
    Hello guys ! Im new here and i´m looking for help at the design of a 24' planing hull.
    The idea is a semi-oceanic boat with a deadrise arrown 10 and 15 degrees with a deep V at the bow.
    If someone have some plans to start drawing or some information i will verry grateful !!
    To be more especific, the craft im designing is a Aluminum Landing Craft.
    i leave a image of the craft i want to modificate to a hull more "marine" with a deadrise of 20° al the transom. and a V shape at the Bow.
  2. S17665
    S17665 Designer
    I will suggest you to have a high value of deadrise over 20 degrees to have more dynamic stability in rough wave condition . I know that increase the roll and fuel consumption but i believe that is important if you want a good seakeeping in Ocean.
  3. TANSL
    Probably I could colaborate with you. What you need: delineation, naval architecture calculations, scantlings, construction drawings, ... ?
    Please e.mail me if interested, to clarify the type of help you are looking for and to exchange information : 657677483@orange.es
  4. PAR
    I disagree with the need for high deadrise, unless this boat has a high top speed goal in it's SOR. You have to sacrifice quite a bit with 20+ degrees of deadrise, which is only tolerable on certain and specific SOR targets.
    A 24' near coastal cruiser, with occasional romps in deep water designs abound and about every design firm has some to select from. Check with Glen-L.com, Bateau.com and the other usual sources.
    This is one of mine and well proven.
  5. Mr Efficiency
    To be built in what material ?
  6. rwatson
    rwatson Senior Member
    28 feet
    Trailerable
    Planes at 16 knots, 22 knots top speed on 70 HP Outboard
  7. TANSL
    NicoARG, as you can see, everyone, trying to help, tries to show the boat from his portfolio that believes best fits your needs. So it would be very important to you to do a better description of what you're looking for.
    rwatson, you have progressed a lot with your 3D models. Congratulations.
  8. NicoARG
    NicoARG New Member
    in Aluminum !! its a landing craft to be more especific.
  9. NicoARG
    NicoARG New Member
    Nice boat !! :cool:
    I expand the description of what im looking for but i will have your design in mind !!
  10. sahad
    sahad New Member
    rwatson, I have some skills in sheet metal work. Very keen on your 28 feet planing hull design. Visually, your design makes an excellent statement. I would like to execute it in steel. What stage are you at right now?
  11. messabout
    messabout Senior Member
    Please be a little more specific about what you mean when you say" Landing craft"
    In the usual parlance, a landing craft is a boat that is a cargo carrier or troop carrier capable of powering up onto a beach while retaining the ability to get itself off the beach unassisted. A deep vee is questionable for such a purpose.
  12. TANSL
    See picture in post #1. That's exactly a "landing craft", imho. A deep vee is questionable for such a purpose, so vee can´t be deep.
  13. Tanton
    Likes: 98, Points: 38, Legacy Rep: 294
    Tanton Senior Member
    Garvey
    Landing craft.
  14. Tad
    Tad Boat Designer
  15. Sailcy
    Sailcy Junior Member
    rwatson very sleek looking boat! Could you tell a bit more about this design please?
