Trip the Light Fandango,
I'm glad to see your response on drilling holes/injecting resin. I have a 32ft Sutphen "cigarette" type boat made for rough water. Twin 502's.
That's exactly what i am doing in the transom. Just trying to get something solid between the fiberglass laminates in the transom especially where the multitude of items that are attached and the laminates squeezed together by bolts (2 trim tabs, 2 hydraulic steering brackets, besides the drives, thru hull exhaust, and the usual other stuff. Tapped with wooden stick everywhere, and drilled quite a few 3/8" holes to check for rot where suspected. But doesn't take too long to do. Completely drying it out first.
This boat has been thru a lot of rough riding before i saw one small transom crack at a stringer, so it must be a very well built transom for the engines/drives to stay perfectly aligned after that much abuse even with the rotting spots. It does have offshore front engine mounts. Next time i will pull both motors and everything, but for now, it's holes and injected resin with a filler, and a good repair at that crack at the top of one stringer.
Thanks for your suggestion. Should work for a stringer as well which I've seen hold up just with the fiberglass and some of the wood gone. Glass is tough. Glad to see somebody mention this. You don't see this done much. But since it's held up, and I now keep the transom dry since I've bought it, I really believe this will make it last quite a while. Mostly to keep the existing laminates in there place, although i agree, not at all as strong as everything properly glued together, but should be more than enough.
Kurt
