colorado_hick
New Member
- Joined
- Mar 15, 2015
- Messages
- Reaction score
- Location
- colorado
I have always been a fan of fiberglass shell travel trailers (like scamps), and have come up with a unique design that I would like to build from the ground up and I think that boat building techniques will be my best bet. goal is ultra light weight and durable (aluminum frame and decking, fiberglass walls and ceiling, no steel or wood)
I am picturing building vertical/roof supports 4' on center out of aluminum angle iron with horizontal aluminum flatbar ribs that tie the supports together. The ribs would have spacers so they were not flush with the supports. THere would be a 1/2 plywood form that was flush with the supports. THen I was going to paint on a release agent and spray on fiberglass so that the ribs were embedded in the final product. All door/cabinets/etc would be hung from aluminum supports.
Then the plywood would come out, and I would do some sort of honeycomb spacer on the inside that is the same thickness ans the angle iron, and a another light coat would go on the inside.
Is there a better approach for a one off design? maybe something like corecell panels that I can use instead of plywood that would give me insulation and end up embedded in the final product? Other general advice from DIY glassers out there? a good book or website to get me started?
thanks!
thanks!
