Use oversized flexible coupling?
Discussion in 'Inboards' started by Allweather26, Mar 6, 2024.
  1. Allweather26
    Allweather26 New Member
    I purchased an R&D flex coupling, but accidentally ordered one with a higher hp rating.
    Does anyone know the consequence of using it?
    Thank you
  2. C. Dog
    Likes: 54, Points: 28
    C. Dog Senior Member
    Strongly suggest you send this question to the manufacturer as it is their baby and they seem dedicated to quality. They have probably encountered your situation several times. Best of luck.
  3. kapnD
    Likes: 414, Points: 83, Legacy Rep: 40
    kapnD Senior Member
    Without a doubt, your boat will go faster while using less fuel!
  4. skaraborgcraft
    Likes: 131, Points: 43
    skaraborgcraft Senior Member
    How much higher HP? Given they are designed to take thrust and flex, I see little issue with it even if over rated, it will still be better than a direct coupling. As long as your alignment is good you shouldnt be putting any undue strain on the box.
  5. seasquirt
    Likes: 55, Points: 28, Legacy Rep: 10
    seasquirt Senior Member
    Hi Allweather, if there is room to accommodate the larger size, and and shaft sizes match so you don't have to source adapters, it is a bonus. The slightly increased weight should make no difference if properly aligned, unless it is out of balance already.
  6. BlueBell
    Likes: 986, Points: 113
    So it's over rated... more drag and more safety margin... embrace it.
    EDIT: How much more...?
  7. kapnD
    kapnD Senior Member
    R&D makes couplings for 5-1500 hp. If you’re reasonably close, and it fits your existing coupling, I don’t see a problem.
  8. comfisherman
    Likes: 344, Points: 63, Legacy Rep: 10
    comfisherman Senior Member
    As mentioned above the range that they cover is very broad. Would think only down side would be less flex.
  1. Runhammar
  2. Nasher
