To me, It is common sense to use the pressure to strengthen the vessel. I have no way of knowing if these engineers have done this.
A two liter Pepsi bottle of helium will not fly but a twenty liter one would. More importantly, an atmosphere filled two liter Pepsi bottle will crush in a trash compactor but one with two atmospheres of pressure will displace a lot of cabbage stems and tin cans before failure.
Looked at another way, If one vacuumed all atmosphere from any hull, would it want to collapse on itself? Yes, to a degree. There would then be 14.7 PSI, (1 Kg/cm) of unopposed pressure on every external surface. Wouldn't doubling the pressure to 30PSI make it that much stronger? If it weren't for losing internal spaces on our boats, they might ALL now be made of polyethylene or have a polyethylene membrain. Dont need to worry too much about a puncture - it's not a mylar balloon.
I'm no engineer, physicist or designer, but I think you're looking at the wrong sort of strength, and not enough of it.
The main stresses on a performance boat include compression from the mast in the order of many tens of tons for an AC boat. The mast jack on the little Melges 32 is used at 3,500 to 4,000 psi. Given that the boat can already take that sort of load, increasing the internal pressure by 30 psi is negligible.
Secondly, the physics don't work as far as I can see. The problems with racing boats are deflection of the skin (under slamming loads of 80psi and more) and maintaining overall shape under those vast loads, and inflatable structures of all sorts are notoriously liable to gross deflection. So inflating the boat does nothing to assist deflection. In fact, while the difference would be minute, it may even increase deflection, because the internal pressure would want to change the shape to a sphere which has more volume.
A pressurised hull also probably does nothing for sheer strength, probably worsens against many tension stresses, and does nothing good for rig, rudder and keel induced stresses. There's a reason inflatables normally sail slowly!
The physics also don't work (AFAIK) because gas pressure is extremely bad at maintaining the rigidity of its containing structure and this goes up dramatically as the volume increases. The problem, simply, is that a hull has so much volume that even if it was crushed to 90% of its volume, the 30psi would only go up to 33 psi, which is still so light that it would have almost no effect when it comes to withstanding the loads of wind and water, as far as I know.
I just walked over to my racing bike. I run time trials at 120 psi, and yet I can easily deflect the tyres of my bike with my fingers despite the fact that the depression I therefore create is significant compared to the volume of that skinny tyre. In contrast, I can't come close to depressing any of my boats or boards (even the polyethylene ones) by a comparable amount.
Basically, boats are built to such high loads that the additional "strength" formed by air pressure isn't enough to do anything to resist the problem loads. On the other hand, pressure CAN cause problems because boats aren't built to withstand it. A windsurfer built of low-density foam is magnitudes stiffer and stronger than my bike tyre at 120 psi, yet the windsurfer can blow apart due to air expansion on a hot day if the pressure-release valve isn't undone. Interestingly, the skin blasted off the core by such air is much FLEXIER than an intact skin, and the board is close to structural failure.
Inflatable surfboats around here seem to run at 4.5 psi max (12.5-ish for the highrisers of a Thundercat) and even the national IRB champ used to be as floppy as all get out. If inflating a boat to become rigid was that easy and efficient, why don't racing IRBs and Thundercats do it?
Basically, the high pressure idea seems to fall foul of basic physics.
Furthermore;
1) We DO have to get inside boats, for sail and gear storage, control lines and wires, masts, maintenance etc.
2) Maintaining internal pressure requires gas-tight construction which adds weight and/or finishing labour.
3) Internal pressure puts load on all areas of the container, whether or not they need "reinforcement" by pressure and whether or not they can take it.
4) The pressure container is neither weightless, costless or hassle-free.
