USA State trailer laws
Discussion in 'Option One' started by FAST FRED, Aug 7, 2012.
  1. whitepointer23
    lots of 5th wheeler caravans and horse floats in australia , much better to tow. i even know of a mini roadtrain, its a toyota landcruiser towing a caravan and a large trailer boat hooked on behind the van.
  2. Frosty
    Frosty Previous Member
    Now that is illegal in Uk --unless you are a farmer or have a showmans license.
  3. whitepointer23
    that landcruiser was in w.a and used to go up the coast for the winter each year, so it was not on the road much , i doubt if it would be legal in the eastern states.
  4. hoytedow
    Piggyback(tandem) trailers are illegal in Florida.
  5. FAST FRED
    FAST FRED Senior Member
    "Class A's (basically bus chassis),",,,, Not so,
    A bus (except a skool bus) doesn't really have a chassis , most are monocoque or semi monocoque.
    The Class A I see most is a stretched truck chassis (Ford or Chevy) or sometimes (higher end) a Spartan .
    Class A just means the entire body is RV , not a stuck on body behind a truck driving area Class C.
    These are usually fine , if the "engineering dept " is willing to accept the factory ratings.
    They get in real trouble adding a pair of air shocks and 6 ft to the chassis and claiming it has a 5000LB better rating.
    The best way to decide on a rig is to buy a RV magazine , and see how many "fixes and cures" are sold for the chassis you like.
    Because some marketing clown claims his Alegro Bus is a bus , doesn't change how its constructed.
    Just because Kittens are be born in the oven , there not MUFFNS!
  6. troy2000
    troy2000 Senior Member
    You're right about the technical definition of class A's vs. class C's, of course. But there are class A's and class A's.
    My old 32' Georgie Boy from the seventies is the sort you're describing. It has a V-8 Dodge engine and transmission. On the other hand, I've seen some seriously high-dollar diesel pushers out there, which are apparently built more like a bus.... those seem to be in an entirely different class.
    Which reminds me: we're up to our keisters in Class A's and Class C's. But is (or was there ever) a Class B motor home?
  7. Ike
    Likes: 484, Points: 83, Legacy Rep: 1669
    Ike Senior Member
  8. philSweet
    Likes: 458, Points: 83, Legacy Rep: 1082
    philSweet Senior Member
  9. troy2000
    Ah. Thanks for enlightening me.
  10. murdomack
    Likes: 23, Points: 18, Legacy Rep: 282
    murdomack New Member
    The goose-neck and the fifth-wheel are two totally different ways of coupling a semi-trailer.
    With a goose-neck arrangement, you have a ball mounted on the truck bed and the receiver coupling is mounted on the goose-neck of the trailer.
    A fifth-wheel is mounted on the tractor chassis that often has ramps that lift a landing plate below the trailer to the correct height. A king-pin is fitted in the middle of this landing plate and locks into the fifth-wheel. The king pin usually measures ~3-1/2"(or ~90mm) in diameter. A smaller diameter version is available in the US.
    http://www.youtube.com/watch?feature=endscreen&v=uvjTXcFDmRc&NR=1
  11. hoytedow
    You are absolutely right, my mistake. Here is an example of an rv 5th wheel hitch receiver. http://www.pplmotorhomes.com/parts/rv-hitches/valley-hitch-5th-wheel.htm
    http://www.pplmotorhomes.com/parts/rv-hitches/Husky-hitch.jpg[​IMG]
  12. hoytedow
  13. murdomack
  14. Ike
    Ike Senior Member
    Sort of. It's about half and half, fifth wheels and motorhomes. My wife and I are full timers and live in our motorhome. We prefer to pull a dinghy ( a car) instead of having a pickup that gets 8 mpg (like my motorhome). So when you are settled you can run around town, or where ever you need to go, in something that doesn't sound like a truck, and gets decent mileage. But there are pros and cons to both.
