Unusual Foil Requirement - Thoughts?
Discussion in 'Hydrodynamics and Aerodynamics' started by PI Design, Jul 19, 2012.
  1. PI Design
    Likes: 21, Points: 0, Legacy Rep: 328
    PI Design Senior Member
    Hi,
    I have an unusual foil brief. I thought I would throw it open to ideas for appropriate sections.
    It needs to be highly buoyant (so tending towards a fat section, >25%), low drag and low lift ( for AOA 0-10 degrees). It also has to be very low aspect ratio, no more than 1.0. Reynolds number approximately 1.5e6.
    Any thoughts on suitable sections very welcome!
  2. jehardiman
    Likes: 1,501, Points: 113, Legacy Rep: 2040
    jehardiman Senior Member
    c/t of 4, correct?
    lifting or non-lifting?
  3. PI Design
    Hi,
    Yes, c/t of 4 or less. Would like no, or very little, lift. I have thought about a cylinder with a hinged, weather cocking, flap but would like no moving parts if possible.
  4. Tim B
    Tim B Senior Member
    What are you designing? it sounds like the stub tank on old flying boats (where interior volume was a constraint). I'm struggling to think of anything else which would produce your requirements.
    Typically, the structure dictates the section thickness, and the operating Cl governs the planform area. Hence you end up with small(ish), thin foils.
    If you have no fluid-dynamic requirement for this appendage, a cylinder faird into the hull might suffice, but without knowing the purpose it's hard to advise.
    Tim B.
  5. PI Design
    Sorry, I don't think I can say more about the design. But fundamentally it needs to be low drag, low lift, fat and low aspect ratio. Is that an impossible combination?
  6. jehardiman
    I'd use a TMB-EPH shape. What you need is exactly what it was designed for...low lift, low cavitation, and fat.
  7. sottorf
    Likes: 20, Points: 0, Legacy Rep: 202
    sottorf member
    it sounds like you are designing somehting like Navatek ships already developed. See http://www.navatekltd.com/seaflyer.html You can find details of the system in the US patent office website. They have already patented the optimum configurations.
    I suggest you contact them or Robert Gornstein (retired). He might be more willing to share info with you than Navatek themselves.
  8. PI Design
    Thanks for that. I followed up the tmb-eph and found myself back here reading through a thread between you and Tom Speer about one of his section that looks promising.
  9. jehardiman
    For what Tom and I were discussing about thickness aft, see this report for the data.
    FREE-STREAM CHARACTERISTICS ,OF A FAMILY OF LOW-ASPECT RATIO, ALL-MOVABLE CONTROL SURFACES FOR APPLICATION TO SHIP DESIGN; L. Folger Whicker, et al, David Taylor Model Basin, Washington, D. C., December 1958.
    http://www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA014272
  10. BMcF
    Likes: 220, Points: 63, Legacy Rep: 361
    BMcF Senior Member
    Do mean something like what we built and tested as shown in the pic below? Extremely low aspect ratio but with some dynamic lift in addition to its bouyant lift...
  11. PI Design
    I'm having a good read right now, thanks
    Yes, something almost exactly like that shape would be great. Can you give me any details, BMcF?
  12. daiquiri
  13. DCockey
    DCockey Participant
    I agree with daiquiri. At an Aspect Ratio of 1 the flow and a thick section the flow will be fundamentally three dimensional which considerably complicates the analysis.
  14. PI Design
    Thanks for the paper Daiquiri. A body of revolution may not (but may, I need to check) fit in the spatial constraint. But perhaps two bodies in a catamaran configuration may be the answer. There would be relatively high skin friction and interference drag, but might still be the best compromise.
  15. BMcF
    BMcF Senior Member
    Aren't many to give, really; those are bouyant bodies, of course, but are shaped with some positive camber fore-aft to produce dynamic lift..so the shape is a "quasi" hydrofoil in the sense that it produces both dynamic and static/bouyant lift when moving through the water.
    1. Daniel Reilly
    2. Paul Scott
    3. Aaarrrggghhh
    4. jmf11
    5. Dieter51
    6. Heimfried
    7. dustman
    8. Maarten88
    9. alan craig
    10. B.NARENDHIRAN
