unexpected loss of heat big problem?
Discussion in 'Materials' started by JLIMA, Nov 1, 2010.
  1. JLIMA
    Likes: 4, Points: 0, Legacy Rep: 130
    JLIMA crazed throttleman
    My workshop has electric heat but the wind the other day knocked it out in the middle of putting fiberglass on the hull. I know it needs a certain temp for the epoxy to cure fully but is 2 days well bellow 40 deg Fahrenheit going to really muck things up to the point that I need to redo it or will bringing up the temp after the wires are repaired tomorrow allow it to fully cure. For what its worth it's been 34 hours and it went into the 20's last night and everything is still quite tacky still....
  2. apex1
    apex1 Guest
    Be happy it is tacky!
    That way your layup does not make any trouble accepting the following layer.
    Leave it as cold as possible until you can provide a proper curing temperature again. Then go ahead with the job.
    Don´t worry it cures thouroughly, once heated again.
    Regards
    Richard
  3. JLIMA
    Ah thank you I may breathe again so all is not lost ....:)
  4. apex1
    apex1 Guest
    You can even have won a few days off!;) Nothing lost.
    In fact, I like cold layups. It makes dead sure you get a proper primary bond.
  5. Man Overboard
    Likes: 13, Points: 18, Legacy Rep: 129
    Man Overboard Tom Fugate
    So can you purposely work in colder temperatures, say 50º (122ºC); and then kick up the shop temp when you are ready to do a full cure. For instance, when you are doing a large layup that you want to vacuum bag, and want more time for layup and bag prep?
  6. alan white
    alan white Senior Member
    Yes. Crank on the heat when you're done.
  7. apex1
    apex1 Guest
    Ähh, yes, and no.
    No, in case you really meant 122°C ! Although some creatures will survive that, the guy on the job will not!:D
    50° Fahrenheit is only 10°C, and that is a perfect temperature to do a entire hull in one go!
    So, yes!;)
    Richard
  8. Petros
    Petros Senior Member
    Usually lower temperatures has the effect of slowing the reaction. It is conceivable that it will eventually cure even at the lower temps (though I would not want to test that on a large structure). Though there is the risk of contamination of the surface if it is stays sticky too long.
  9. apex1
    apex1 Guest
    Always lower temp. slows down the reaction.
    The curing can be severely effected when it sits too long at low temperatures, and finally cures at the surface. There is no guarantee that it cured fully to the quality it would have when cured at the recommended temperature!
    But that will not happen here, we are talking days, not weeks or months.
    Regards
    Richard
  10. Man Overboard
    Ha ha, Ya I don't know why that didn't stand out as being wrong. I accidentally converted 50C to F, (and then posted it as C) instead of the other way around.
  11. Herman
    Herman Senior Member
    That is the nice thing about epoxy. At lower temperatures it does not reach a full cure, and everything bonded to it will achieve a good bond. After all bonding is done, crank up the temperature and postcure the whole part.
