If one pitched the two ends of taffy consistencey hdpe (theromforing) to from a racked bow, is it possible with out folds or stretching to much? Shape wise...it's like slapping dough onto an oval bowl. Idk if i am imaging this working right...help?
What kinda examples of raked bows with quick transitions to full belly hulls do you all know of?
Secondly i plan on fusion welding small blocks to the inner hull and then perrallel with the hull put a bolt thru attaching to a bulkhead. How much poorer (or the same) than perbenducular to hull into bulk head like normal?
Another side question is, as the triangle is stronger than rectangle, why don't ship use a triangular lattice? Just look at a Bridge.
