Ultra Beginner questions : mould building.
Discussion in 'Fiberglass and Composite Boat Building' started by fcfc, Nov 7, 2011.
  1. fcfc
    Likes: 30, Points: 28, Legacy Rep: 399
    fcfc Senior Member
    Is building a female mold directly is a viable option, or do you need to build a plug first, and build the mold on that plug ?
    There were photos of an express 40 mould built directly, but the company seems to no longer exists, and photos have gone.
    Mould for infusion, in two halves or with removable flanges for deck , not expected to be used for more than 2-3 units. Rather easy sailboat hull form in 28-33 ft range. Boat to be gelcoated, not painted.
    Nb a bunch of other issues are to be solved , such as deck manufacturing/joining and may change hull mould options (flanges ...)
  2. wet feet
    Likes: 557, Points: 113, Legacy Rep: 124
    wet feet Senior Member
    It might be possible to create a female mould,but I doubt that people would be fighting to be allowed to fair the surface.I would also think you would be headed for leakage problems if you tried infusion,but maybe a coating of an impermeable material would help.I would have fewer concerns about building a female mould for the deck and coachroof,except for the challenge of making it actually fit the hull.
  3. fcfc
    fcfc Senior Member
    Seems some does it : http://www.3dwmoulds.com/cont_E_178.phtml
    At least for the hull. For the deck, it is unclear. Looks a plug buit on the hull or on the mold.
    How the fairing is done is unknown. It look they have a very small station spacing.
  4. waikikin
    waikikin Senior Member
  5. Vbeas87
    Vbeas87 New Member
    since this is the beginner mould building... talking about a tunnel hull?
  6. gonzo
    Likes: 2,057, Points: 123, Legacy Rep: 2031
    If build the mold with CNC it doesn't matter.
