U-joint, CV-joint, Thompson coupling
Discussion in 'Propulsion' started by brian eiland, Mar 16, 2007.
  1. brian eiland
    Likes: 222, Points: 73, Legacy Rep: 1903
    brian eiland Senior Member
  2. Guillermo
    Likes: 191, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
    Interesting. Thanks Brian.
  3. FAST FRED
    FAST FRED Senior Member
    TECH Fallout is getting faster and faster , but if you think boat stuff is expensive , wait till you purchase from the Helicopter folks parts bin!,
    Still waiting for boats to use a common power bus (ring) and electric for simple controls to operate hyd power packs , done on fighters for decades.
    Imagine a windlass or bow thruster with no service time limits , and the no blown fuses of hyd power!
    FF
  4. SeaJay
    Likes: 5, Points: 0, Legacy Rep: 112
    SeaJay Senior Member
    I want one!
  5. mjbtx
    mjbtx New Member
    Cool stuff. Need some to replace my merc cv couplings.
  6. Landlubber
    Landlubber Senior Member
    Thanks Brian, it is unbelievable.
  7. Frosty
    Frosty Previous Member
    Well I tried to down load the movie but 1: hour 45minutes was just too much. It looks like a normal UJ in a frame???
  8. Landlubber
    That is the brilliant simplicity of this Frosty, it really is just a double version, but the second ring makes it all work. It truely is a CV joint.
    Most good inventions are simple.
    I am simple, but can only try to be good.
    Where did I go wrong, I can nod my head up and down move it left and right and even pivot it at the same time, but not in CV.....
    Maybe this conversation should be in the drivel thread eh
  9. brian eiland
  10. DCockey
    Likes: 664, Points: 113, Legacy Rep: 1485
    DCockey Participant
    Why would the Thompson joint be better than any of the multitude of other CV joints currently available?
    Does the amartech RPS even need a CV joint? Based on the illustration in their website it appears to me that the shaft is only turning with the unit deployed and the angle change of the shaft in the swivel joint is small enough that a simple Carden joint would be sufficient.
  11. brian eiland
    You might recall that in a propeller application the prop is transmitting a very appreciable thrust load up the shaft (axial load to the joint). Most CV's and Carden joints don't like high axial loading.
  12. DCockey
    DCockey Participant
    The Thompson joint is similar to a nested double Cardan joint. No reason it would be any happier with axial loading than a Cardan joint. Corvettes for many years used the half-shafts with Cardan joints on the ends as the upper lateral control links for the rear suspension and those joints saw axial loads. Also some CV joints are designed for axial loads.
    No reason a propeller shaft has to transmit thrust to a U-joint. A thrust bearing can be used between the propeller and the U-joint.
    Looking at the drawing of the Amartech RPS system on their website (click on the illustration and then click on the arrows for the third slide) it appears that it uses a thrust bearing at the end of the propeller shaft in the swivel joint housing.
    Several firms produce propeller shaft systems which use a seal and thrust bearing in the stern post, with an intermediated shaft which Cardan joints at either end between the thrust bearing and the engine/reverse gear. Advantages include allowing soft mounting of the engine for reduced vibration. I'd consider it proven technology for boats in the small and medium size range.
  13. Petros
    Petros Senior Member
    that is a great invention, would make u-joints and cv joints obsolete. looks costly to manufacture however, too many detail parts, so not likely we will ever get to see them on mass produced cars.
  14. mydauphin
    mydauphin Senior Member
    I am still looking for an inexpensive thrust bearing, the CV joints aren't the problem.
  15. brian eiland
    I'm not saying that Cardan joints don't accept axial loads, but when you are directing pushing maybe 200-400 hp thru them to push your vessel, i don't believe they would hold up for long
    Here is that dwg. I'm not so sure you could place the trust bearing in the rotating member and have it do its job properly. I suspect the trust bearing is after the 'pivotable joint' where the shaft enters the hull??
    Understood. One must also consider extracting the prop shaft for servicing, particularly in the case of bending the shaft upon striking an object
