Two Stern Thrusters next to each other
Discussion in 'Hydrodynamics and Aerodynamics' started by Lewardsail, Feb 27, 2015.
  1. Lewardsail
    Lewardsail New Member
    Has there been and testing of two stern thrusters close together and what if any effects this causes.
    I know some bow thrusters have two counter rotating props, does this make it more efficient?
    Any information would be helpfull.
    Thanks,
    Lewardsail
  2. DCockey
    Likes: 658, Points: 113, Legacy Rep: 1485
    DCockey Participant
    Counter-rotating concentric props can (if properly designed) improve efficiency by reducing swirl in the water stream exiting the props. With a single propeller the water stream exiting the prop is swirling and the swirl does not contribute to thrust.
    The propellers must be counter-roatating, concentric and properly designed to reduce the swirl and improve efficiency. Otherwise efficiency may be worse than with a single propeller.
  3. powerabout
    powerabout Senior Member
    Do you mean 2 tunnels or 2 azimuthing thrusters?
    I think the other advantage of duo props is small diameter to equal the thrust of a larger diameter
