Twin Outboards
Discussion in 'Outboards' started by m11kyg, Jan 1, 2020.
  1. m11kyg
    m11kyg New Member
    Hi Guys,
    I'm looking to mount twin Verados on my boat, although Merc say they should be mounted at 26" does it matter if I go any wider??
    Cheers
    Mike
    boats for sale uk
  2. Barry
    Likes: 131, Points: 63, Legacy Rep: 158
    Barry Senior Member
    What is the width of the chine at the transom, assuming that it is a mono hull, deadrise degree. length of the boat, and are you considering trim tabs?
    More info will help a better response.
    And because of the question, do you think that there is an advantage to go wider?
  3. Mr Efficiency
    Likes: 473, Points: 83, Legacy Rep: 702
    Good questions by Barry, there are a number of reasons why closer might be better, but the minimum is usually set according to the need to avoid the two props interfering with the other, and going too wide could mean, depending on the hull geometry, earlier ventilation in a straight line, as well as turning.
  4. gonzo
    Likes: 586, Points: 123, Legacy Rep: 2031
    The link goes to a boat sales website. Is this to show the boat or spam?
