tpenfield
Senior Member
- Joined
- Dec 10, 2016
- Messages
- 601
- Reaction score
- 251
- Location
- Cape Cod, MA - USA
I am modifying the bracket design to provide an air gap between the underside of the swim deck and the top surface of the bracket. I'll have a few 'tabs' to fasten to the lower edge of the swim deck in several places along its radius. This approach should be easier to design/fabricate, because the transom angle does not have to be as precise. I measured the transom angle to be 12.5˚ +/-. The manufacturer of the boat has their bracket with a transom angle of 16˚, which I think is a bit excessive. (Probably to give the outboards extra 'in' trim). I probably will go with a 14˚ transom angle at the bracket as a compromise between the 12˚ and 16˚.
Also, the maker of the bracket for the Chappy 327 states in their product information that they use a combination of 6061 and 5052 series aluminum. My nautical engineering sources tell me that 5083 series would be better ( accordingly more expensive, but not a deal breaker ).
As a next step, I may try to make a fairly accurate 3D model of the transom of my boat. It has a lot of unusual shapes and angle and is deeply inset under the swim deck.
