I am keen to get some feedback on my thought and pros/cons of controllable pitch propeller (CPP) on a twin engine displacement boat.
I am in very early concept design stage of a new boat which hopefully will be built one day! I have read all the pros/cons of single engine boats, and twin engine boats. My boat will be in the region of 60ft/60t and I like the idea of two engines for redundancy.
For discussion sake say I need a 300hp engine, or two at 150hp, and boat need 120hp (40% of full load) to push the boat at 8knots and 1400rpm, and WOT at 1800rpm and 10knots and engine is M1 continuous duty rated . So my query is what will happen if operated the boat on one engine? I have the hp to run at 8 knots, but a prop will be pitched wrong so will I overload the engine with a normal prop? Often people operating a twin engine boat on one engine and reducing fuel consumption by say 15% but what got me thinking was seeing a picture of a similar boat as I am envisaging with black soot all over the top of the boat which could overloading of the engine.
If both props are CPP then the operating engine/prop can be pitched to the most appropriate pitch with either one or two operating engines, and the non-operating prop fully feathered.
So if this all makes sense why are so is this not more common (or i have found zero examples), is it just cost? but the costing I have so far indicate only a small additional cost.
