Twin diesel / generator / single shaft prop setup
Discussion in 'Propulsion' started by SeaSpark, Apr 22, 2006.
  1. SeaSpark
    Likes: 17, Points: 0, Legacy Rep: 96
    SeaSpark -
    Looking for opinions on the following setup:
    It is a drive / generator system for a sailboat.
    It has a single shaft prop to reduce resistance when sailing, the variable pitch prop can be "vaned" to further reduce it.
    The twin diesel setup makes it reliable and economical, in calm conditions cruising speed can be reached with one engine.
    When charging only one diesel has to be coupled to the generator.
    When sailing the prop can be set to very large pitch and so drive the generator.
    The belt drive couplings can be exchangeable to enhance reliability.
  2. Guillermo
    Likes: 188, Points: 63, Legacy Rep: 2247
    Guillermo Ingeniero Naval
  3. SeaSpark
    SeaSpark -
    Diesel electric
    Diesel electric is a very serious alternative.
    This system relies less on electronics which are always vulnerable on a ship.
    A diesel electric system with one diesel is less reliable then a boat that can depend on two diesels for propulsion.
    Thanks for the lateral thinking compliment!
