Tunnel in Hull
Discussion in 'Hydrodynamics and Aerodynamics' started by Bukmaster9, Jun 18, 2021.
  1. Barry
    Likes: 649, Points: 113, Legacy Rep: 158
    Barry Senior Member
    It would appear that the dead rise is around 10ish degrees
    With 400 available hp, this boat should fly. our 28 foot aluminum with twin 250’s, pilothouse, 9000 pounds does 54 mph, full cabin, estimated deadrise over 20 degrees.
    There are 2 tunnel issues. (These issues may not manifest but we have seen the following occur albeit with slightly different
    parameters)
    1) At a high speed the wetted area, depending on trim, may be very short. About a 1/4 to 1/3 of the way back from the leading edge of wetted surface there is a high pressure area, the stagnation line. If at high speed the tunnel reaches this area, there is a good chance that the boat may begin to porpoise.
    2) Our very first 6 degree outboard jet we installed a tunnel, we did not install lift strakes as we decided that with that shallow of V they may not provide additional lift. We did not realize the importance/significance of of keeping the boat from sliding in a turn. During a tight turn to say starboard the port edge of the tunnel would ventilate from the air from the transom, ie become part of the trailing edge and the pump intake would suck air. I would predict that this interrupted air entrained flow to your prop inlet water could cause issues even though your motor is set back off on a bracket
    The consensus appears to be “lose the tunnel”.
  2. jorgepease
    jorgepease Senior Member
    The portabrackets set your motor way back and have a ton of travel, good for no-tunnel boats, pair that with a Bob's nose cone and you could still run really skinny without the tunnel.
    I agree the 400 is overkill but it can be to your advantage if you are carrying heavy loads and want/need a prop with cupping. It eats up horsepower but you will be able to run the prop above the surface and have all the bite you need for carrying heavy loads, even in skinny water.. Check Bauman Marine in Houston for that, they are good.
  3. Bukmaster9
    Likes: 1, Points: 3
    Bukmaster9 Junior Member
    Thanks for the input. It is appreciated.
    1. Howlandwoodworks
    2. dynaplane
    3. CarlosK2
    4. Toepfer Marine
    5. Erwan
    6. Tyler Flowers
    7. rsskarthikeyan
    8. longcours62
    9. JordanMay
    10. Jamie Kennedy 108
