Tunnel in Hull
Discussion in 'Hydrodynamics and Aerodynamics' started by Bukmaster9, Jun 18, 2021.
  1. DCockey
    DCockey Participant
    Where was anything said about use offshore?
  2. Mr Efficiency
    New Orleans is on the Gulf Coast, seems a reasonable assumption it will venture out there
  3. Bukmaster9
    Likes: 1, Points: 3
    Bukmaster9 Junior Member
    Mr Efficiency, we fish out of Shell Beach Louisiana . We do not fish offshore, although we will go into Breton Sound on good weather days. Primarily we fish the lakes, bays and bayous. There are boats just like this one around the camp with 350s on them and they do just fine. This boat will be stretched to 27, the 400 will probably cruise at 35mph and in the bays etc that's plenty doable.
  4. Bukmaster9
    Likes: 1, Points: 3
    Here are the other pictures I have
  5. jorgepease
    jorgepease Senior Member
    If you want ability to run shallow, continue the tunnel to the new transom and hang your outboard on a jackplate. But if you want pure speed, the tunnel can rob you of some of that.
  6. Mr Efficiency
    The pictures were not posted, Bukmaster9 ?
  7. Mr Efficiency
    I would get rid of the tunnel.
    TANSL and jorgepease like this.
  8. Bukmaster9
    Likes: 1, Points: 3
    Not sure why they don't show up for you. They show up on my screen. Let me try a different way
  9. Bukmaster9
    Likes: 1, Points: 3
  10. Bukmaster9
    Likes: 1, Points: 3
  11. jorgepease
    I'd be tempted to keep the tunnel on that boat.
  12. Bukmaster9
    Likes: 1, Points: 3
    A big problem is it greatly interferes with the bilge space for sea chest etc
  13. kapnD
    Likes: 601, Points: 113, Legacy Rep: 40
    kapnD Senior Member
    Looks like the demolition stage is just starting, plenty more rotten wood in there yet!
    I’d get the hull off the trailer and well cradled before taking out much more structure, so it doesn’t loose its shape.
  14. Mr Efficiency
    Yes, thanks for attending to that
  15. Mr Efficiency
    OK, well it certainly is not an offshore boat. Unless you have the need to cover a lot of distance quickly, and it better be on calm/semi-calm conditions, I think a 400 hp Verado is about twice what you need
    1. Howlandwoodworks
    2. dynaplane
    3. CarlosK2
    4. Toepfer Marine
    5. Erwan
    6. Tyler Flowers
    7. rsskarthikeyan
    8. longcours62
    9. JordanMay
    10. Jamie Kennedy 108
