Ilan Voyager
Senior Member
- Joined
- May 13, 2004
- Posts
- 1,294
- Reaction score
- 244
- Location
- Paris France
Thanks Angelique for the laugh...
Riveted aluminium boats are born after WWII taking the methods and tooling for fabricating airplanes. By essence it's an industrial method of building boats as it requires a lot of tools and a few skilled workers. It's also rather lengthy as hundreds of holes and rivets are used. Traditionally these boats are made in 6061, an easy to work alloy and found rather cheaply everywhere and these boats are designed for use in fresh water.
Riveted alu it's not the easiest nor the cheapest method for a single DIY flat boat 16 feet...
Alu has another drawback for a small boat; density 2.7 kg/liter. While GRP is about 1.5 and plywood 0.6 to 0.7. That means that for the same weight for a square meter a plywood skin is around 4 times thicker than the alu one and its rigidity is 4^3 times higher.
A piece of 12 mm plywood is far more rigid (I do not mean stronger) than a 3 mm alu so it needs far less structure. I won't enter in the arcanes of weight/rigidity ratios in structural boat engineering and thus the superiority of thick lightweight skins as composites sandwiches and honeycombs.
Plywood is worked with simple home tooling, can be glued, nailed and screwed in all meanings of the word in a humble garage. It can be made dirt cheap if destined for a small river boat, for a Sunday holidays use and kept dry in storage.
In France the CTBX grade plywood is perfect for such little boats.
