My goal is trying to build a 14ft Jon boat under $400. However, I don't just want a regular jon boat so it's hard to find plans. I want to have a modified-v hull, but I still want it to be flat bottom. I would use it to fish and hunt in rivers and sometimes on lakes, flat bottoms hulls on semi-choppy lakes aren't fun. Most of the plans I have found have horizontal benches to help support the side. Well I don't want horizontal benches because they are a pain to jump over when you're on a boat by yourself. I want to have a bench at the back of the boat by the motor and the front decked out about 3 foot. I also wouldn't want framing on the bottom of the boat because I don't like tripping on them. I'm sure they are much more smaller on wooden boats compared to aluminum frame pieces so it may not be as bad as I think. If some one else comes with me I'll just throw a cooler in the middle vertically for a bench, or maybe build a vertical bench onto it later on. And it's being powered by a 7hp long tail so the lighter the better.
So I have a couple questions:
What is the best way to build the boat, frame it out or stitch and glue?
Since I don't want floor supports sticking up is there a different way to support the sides of the boat or should the front decking of the boat and back bench be enough to support the sides?
Anybody seen any plans similar to what I described? I saw 15ft Garvey plans that look kinda like what I want but I want one thats 14ft and it's cost of build was estimated at $1200 and it wasn't a flat bottom.
