Tropical Wood Catamaran Boat
Discussion in 'Boat Design' started by somarine, May 16, 2020.
  1. bajansailor
    Likes: 1,574, Points: 113, Legacy Rep: 37
    bajansailor Marine Surveyor
    I had a similar experience 22 years ago with the first plywood 2 part nesting dinghy I built.
    I lavished epoxy on it inside and out (with a layer of cloth on the outside as well), but I built it in the middle of our rainy season in the tropics (with very high humidity) and a few years later the plywood had all rotted , leaving just a very wobbly single layer of glass cloth with epoxy claiming to be my dinghy..
    I had taken a mould of it before it rotted away, and a mate and I built a couple of GRP versions for ourselves. My GRP one is still fine - or at least the GRP is - however there is not much left of the pine gunwhales now after they were savaged by termites.
    I am trying to work up some enthusiasm now to replace them - I think that there will be no wood involved......
    Edit - do termites like slightly soggy plywood? I wonder if they chomped on the plywood as well as the gunwhales.
    fallguy likes this.
  2. Mr Efficiency
    Moral of the story, don't encapsulate ? Polyester had a reputation, I don't know how well deserved, as inhibiting rot in encapsulated timber, one wonders how epoxy which is virtually waterproof, would not act to inhibit through lack of exchange of moisture, maybe that is the problem, the moisture can't get out.
    bajansailor likes this.
  3. fallguy
    Likes: 1,684, Points: 123, Legacy Rep: 10
    fallguy Senior Member
    moral of the story is build fast and not in a rainy season
  4. Mr Efficiency
    There are a few factors to consider, species durability not least.
  5. clmanges
    Likes: 144, Points: 43, Legacy Rep: 32
    clmanges Senior Member
    I don't know about the plywood, but they are powerfully attracted to wetted particle board (even after it's dried). The particle board turns to sponge anyway, but of course, the critters attack the other structural stuff while they're there. Make what you will of that.
  6. somarine
    Likes: 1, Points: 3
    somarine Junior Member
    Hi bajansailor,
    I am so grateful for my plan and thought to be critic to enable me learn to do this project the right way.
  7. somarine
    Likes: 1, Points: 3
    Hi upchurchmr,
    Yes you are right planks are of canoe size Thickness 1/2'' x Width about 25" x Length about 15' but size will depend where a plank will be install install.
    Joint will be skiff and epoxy, cutter sunk head screws will be used with wood plugs to prevent water from entering. It is also understood that wood boat has a lot of maintenance work. I remember when I was helping my uncle in fishing days, when will return from the waters we will clean the canoe of foils and pull the canoe out of the waters to dry and it largely prevent the wood from damage.
    But of cause it is impossible to do that with a cat.
    Thank
  8. fallguy
    'Of cause' is not proper English...
    it is 'of course'...
    best regards...
  9. somarine
    Likes: 1, Points: 3
    Thank you very much for the correction
    fallguy likes this.
  10. Mr Efficiency
    LOL, we knew what you meant, somarine.
    fallguy likes this.
  11. somarine
    Likes: 1, Points: 3
    My prototype Hull
    Thanks all
  12. fallguy
    hull bottom looks a bit narrow to me, but not a big fan of telling you because all I have is another designer's plans as basis, we you going for just a displacement hull or semi?
    I see electric motors as well. Those are pretty costly and you won't have much range. Is this a real ship or a project for school?
  13. somarine
    Likes: 1, Points: 3
    Hi fallguy,
    "hull bottom looks a bit narrow" yes I am trying Deep V-hull in this project. The Project is LOA : 8' LWL: 7.5'. I do not intend to use this as a real ship but instead using it to learn the tricks and tips towards my 11m ship.
    My current problem is the wood bit,
  14. Rumars
    Likes: 1,123, Points: 113, Legacy Rep: 39
    Rumars Senior Member
  15. somarine
    Likes: 1, Points: 3
    Thanks Rumars
    It really encourages
